[petsc-dev] dates of last change on PETSc web pages
Tue Mar 20 16:02:24 CDT 2012
On Tue, Mar 20, 2012 at 3:49 PM, Sean Farley <sean at mcs.anl.gov> wrote:
> You have not yet modified the script that prepares the manual pages to
>> automatically put the date of generation in the upper right corner.  As
>> well as other generated pages.
>> Could you please add that ASAP or speak to me about how to do it so it
>> will be ready for the next release.
> I also meant to do this but got distracted. I mocked up two versions: one
> with the date below the line (but affects some of the formatting in the
> main body as you can see from the screenshot), and one with the date above
> the line that uses the current space between the header text and the
> horizontal rule.
> I thought the upper right hand corner would look bad but it is better than
> I imagined.
> Thoughts?
I like the corner. It does not get confused with the headings.
    Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120320/fd0a1a8b/attachment.html>
