[petsc-dev] dates of last change on PETSc web pages
Barry Smith
bsmith at mcs.anl.gov
Tue Mar 20 16:08:55 CDT 2012
Upper right corner looks great!
Is this something that can be set automagically from the last Mecurial change for the file? That would absolutely rock.
Barry
On Mar 20, 2012, at 3:49 PM, Sean Farley wrote:
> You have not yet modified the script that prepares the manual pages to automatically put the date of generation in the upper right corner. As well as other generated pages.
> Could you please add that ASAP or speak to me about how to do it so it will be ready for the next release.
> I also meant to do this but got distracted. I mocked up two versions: one with the date below the line (but affects some of the formatting in the main body as you can see from the screenshot), and one with the date above the line that uses the current space between the header text and the horizontal rule.
> I thought the upper right hand corner would look bad but it is better than I imagined.
> Thoughts?
> <date-below-line.png><date-above-line.png><date-upper-right.png>
