[petsc-dev] petsc release soon
Jed Brown
jedbrown at mcs.anl.gov
Tue Mar 13 08:40:20 CDT 2012
The code is still pretty rough/not entirely portable, so I don't think we
will turn it on by default. Having a runable example is important. If you
want to get it ready, I would try to do it in the next week or so.
On Mar 13, 2012 8:15 AM, "Stefano Zampini" <stefano.zampini at gmail.com>
wrote:
> Are you planning to include pcbddc in the next release?
> It works, but some parts of PCBDDC code are not fully developed as we
> decided with Jed (primarly, the MatPartitioning procedure for multilevel).
> In case you want to include it into the next release, how many days I have
> to work on the code until the release ?
> 2012/3/12 Jed Brown <jedbrown at mcs.anl.gov>
>> On Mon, Mar 12, 2012 at 14:40, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> I still like including the private in the name since it makes clear
>>> they are private include files.
>> Cool, glad that's out of the way.
>> Now about namespacing all the variables in the makefiles. This is an
>> opportunity to clarify/normalize variable names. I don't know what
>> SL_LINKER is, for example.
>> Also, should there be an "exported" version that makes some of the PETSC
>> symbols public? (I think so, even just for internal use, because I don't
>> want to type ${PETSC_MPIEXEC}, ${PETSC_DIFF}, ${PETSC_PYTHON}, etc in all
>> the makefiles.)
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120313/177dfc14/attachment.html>
