[petsc-dev] Building PETSC (in Cygwin) with Parmetis
    Matthew Knepley
    knepley at gmail.com
    Wed Mar  7 08:18:56 CST 2012
On Wed, Mar 7, 2012 at 8:01 AM, Chen S <chensp2602 at gmail.com> wrote:
> Hi
> I'm using cygwin to build and configure PETSC , with Parmetis.
> the problem is I can't find a configure command which works for me.
> I have built Parmetis and Metis (and got parmetis.lib and metis.lib) , but
> then everytime I tried to configure PETSC
> (with Parmetis) it didn't work.
> I've tried a lot of variations of the following commands:
> --with-metis-dir=<metis_dir>
> --with-parmetis-dir=<parmetis_dir>
> --with-parmetis-include=<include_dir>
> --with-parmetis-lib="-L<lib_dir>"
> --with-metis=1
> but none of them worked, I always got errors which said "metis/parmetis
> ... did not work"
> (without Parmetis, the configure command works and I can build PETSC)
> do you have any idea which configure command will work for me?
1) This belongs on petsc-maint at mcs.anl.gov
2) Without configure.log, we can tell you anything.
  Matt
> Thank you,
> Chen
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120307/3b90bcb0/attachment.html>
