[petsc-dev] OpenMP/Vec
Lawrence Mitchell
lawrence.mitchell at ed.ac.uk
Wed Mar 7 09:12:52 CST 2012
On 28/02/2012 20:18, Jed Brown wrote:
> I prefer inlining the loop bounds into macro/function calls at point of
> use, rather than relying on magic names from a macro definition, but I'm
> not completely wedded to the idea.
> Not a big deal, we could optimize either variant.
Moving forward, I've done a bunch of this macroisation, which makes the code
more PETSc-like.
As you point out it's probably unwise to call omp_get_num_threads() on every
loop iteration, so I went for the magic names in the end. A typical simple
loop now looks like:
VecOMPParallelBegin(xin, private(i) shared(x));
for (i=__start; i<__end;i++) x[i] = work(x[i]);
VecOMPParallelEnd();
In the --without-openmp case, this transforms into:
do {
PetscInt __start = 0, __end = xin->map->n;
for ...;
} while (0);
Rather than adding an nthreads slot to vectors, I put it in the generic
PetscObject struct -- we're threading matrices too.
I don't know how to write the correct tests for configure to probe for the
existance of _Pragma, so that's still missing.
Cheers,
Lawrence
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
