[petsc-dev] Building PETSC (in Cygwin) with Parmetis
Chen S
chensp2602 at gmail.com
Wed Mar 7 08:01:38 CST 2012
Hi
I'm using cygwin to build and configure PETSC , with Parmetis.
the problem is I can't find a configure command which works for me.
I have built Parmetis and Metis (and got parmetis.lib and metis.lib) , but
then everytime I tried to configure PETSC
(with Parmetis) it didn't work.
I've tried a lot of variations of the following commands:
--with-metis-dir=<metis_dir>
--with-parmetis-dir=<parmetis_dir>
--with-parmetis-include=<include_dir>
--with-parmetis-lib="-L<lib_dir>"
--with-metis=1
but none of them worked, I always got errors which said "metis/parmetis ...
did not work"
(without Parmetis, the configure command works and I can build PETSC)
do you have any idea which configure command will work for me?
Thank you,
Chen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120307/2cd7b664/attachment.html>
