[petsc-dev] [petsc-maint #129715] __float128 complex
Jose E. Roman
jroman at dsic.upv.es
Fri Aug 24 10:53:48 CDT 2012
El 24/08/2012, a las 13:57, Alexander Grayver escribió:
> Jose,
> Thanks!
> One issue. I saw there is special treatment for quad precision in PetscBinaryRead:
> #if defined(PETSC_USE_REAL___FLOAT128)
> double *ppp;
> #endif
> /* If using __float128 precision we still read in doubles from file */
> if (type == PETSC_SCALAR) {
> m = m/2;
> ierr = PetscMalloc(n*sizeof(double),&ppp);CHKERRQ(ierr);
> pp = (char*)ppp;
> #endif
> As far as I can see it doesn't take into account complex numbers currently?
I guess PETSC_SCALAR should be correctly defined for the case complex+__float128 in petscsys.h. Maybe a new PetscDataType PETSC___COMPLEX128? This would require changing PetscMPIDataTypeToPetscDataType and then PetscBinaryRead...
It is better if someone else can be in charge of this change.
Jose
