[petsc-dev] [petsc-maint #129715] __float128 complex
Alexander Grayver
agrayver at gfz-potsdam.de
Fri Aug 24 06:57:36 CDT 2012
Jose,
Thanks!
One issue. I saw there is special treatment for quad precision in
PetscBinaryRead:
#if defined(PETSC_USE_REAL___FLOAT128)
double *ppp;
#endif
/* If using __float128 precision we still read in doubles from file */
if (type == PETSC_SCALAR) {
m = m/2;
ierr = PetscMalloc(n*sizeof(double),&ppp);CHKERRQ(ierr);
pp = (char*)ppp;
#endif
As far as I can see it doesn't take into account complex numbers currently?
On 23.08.2012 18:02, Jose E. Roman wrote:
> I have pushed a change to petsc-dev that allows to configure --with-precision=__float128 --with-scalar-type=complex
> I have tested this with src/ksp/ksp/examples/tutorials/ex12.c with 1 and 2 processes. It seems to work.
> Please review the change, since I had to modify pinit.c
> A couple of comments:
> 1) The f2cblaslapack interface to quad precision subroutines (q* and w*) is defined only in the case of "uscore" mangling. Maybe a test in configure should assure this.
> 2) I could not make it work --with-clanguage=c++ - I get compilation errors like this. Any idea?
Alexander
