[petsc-dev] [petsc-maint #129715] __float128 complex
    Alexander Grayver
    agrayver at gfz-potsdam.de
    Fri Aug 24 10:55:28 CDT 2012
On 24.08.2012 17:53, Jose E. Roman wrote:
> I guess PETSC_SCALAR should be correctly defined for the case complex+__float128 in petscsys.h. Maybe a new PetscDataType PETSC___COMPLEX128? This would require changing PetscMPIDataTypeToPetscDataType and then PetscBinaryRead...
> It is better if someone else can be in charge of this change.
It is not necessary, I can write a kind of convertor myself. Otherwise
complex128 seems to be working.
Alexander
