[petsc-dev] YAML patch
Sean Farley sean at mcs.anl.gov
Wed Aug 8 09:39:14 CDT 2012
> The existing, but non working, function is called PetscOptionsInsertFile_YAML. I just kept its name without checking the petsc developer style guide. My mistake.
> The attached patch fixes this issue.
"There is a limit of 128,000 char on the file length." … What? The old
function had a (temporary) limit of 128,000 characters *per line* but
both approaches should be using Petscgetline().
