[petsc-dev] YAML patch
    Blaise Bourdin
    bourdin at lsu.edu
    Wed Aug  8 09:22:46 CDT 2012
The existing, but non working, function is called PetscOptionsInsertFile_YAML. I just kept its name without checking the petsc developer style guide. My mistake.
The attached patch fixes this issue.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120808/85ec6427/attachment.obj>
Blaise
>   Home come there is an _ before the YAML in the function name?  We put in _ in function names for private functions and generally user called public functions (like this) would not have that.
>    Barry
> On Aug 7, 2012, at 9:29 AM, Blaise Bourdin <bourdin at lsu.edu> wrote:
>> Hi,
>> My YAML patch did not exactly raise much enthusiasm so I tried to clean it up a bit...
>> The attached patch is another attempt at providing partial support for parsing YAML files:  -options_file_yaml now works from C and fortran. It's logic was changed so that it does not require reinserting the whole option string. Aliases and sequences are still not supported.
>> Is this patch worth being pushed to petsc-dev and petsc-3.3?
>> Blaise
>> <PetscOptionsInsertFile_YAML.patch>
>> Department of Mathematics and Center for Computation & Technology
>> Louisiana State University, Baton Rouge, LA 70803, USA
>> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
