[petsc-dev] YAML patch
    Barry Smith
    bsmith at mcs.anl.gov
    Tue Aug  7 17:06:17 CDT 2012
   Home come there is an _ before the YAML in the function name?  We put in _ in function names for private functions and generally user called public functions (like this) would not have that.
    Barry
On Aug 7, 2012, at 9:29 AM, Blaise Bourdin <bourdin at lsu.edu> wrote:
> Hi,
> My YAML patch did not exactly raise much enthusiasm so I tried to clean it up a bit...
> The attached patch is another attempt at providing partial support for parsing YAML files:  -options_file_yaml now works from C and fortran. It's logic was changed so that it does not require reinserting the whole option string. Aliases and sequences are still not supported.
> Is this patch worth being pushed to petsc-dev and petsc-3.3?
> Blaise
> <PetscOptionsInsertFile_YAML.patch>
> Department of Mathematics and Center for Computation & Technology
> Louisiana State University, Baton Rouge, LA 70803, USA
> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
