[petsc-dev] YAML patch
    Blaise Bourdin
    bourdin at lsu.edu
    Tue Aug  7 09:29:38 CDT 2012
My YAML patch did not exactly raise much enthusiasm so I tried to clean it up a bit...
The attached patch is another attempt at providing partial support for parsing YAML files:  -options_file_yaml now works from C and fortran. It's logic was changed so that it does not require reinserting the whole option string. Aliases and sequences are still not supported.
Is this patch worth being pushed to petsc-dev and petsc-3.3?
Blaise
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120807/8abdf74e/attachment.obj>
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
