[petsc-dev] Recommended Petsc Build Procedure
    Matthew Knepley
    knepley at gmail.com
    Sun Apr 22 09:56:15 CDT 2012
On Sun, Apr 22, 2012 at 10:42 AM, Dave Nystrom <
Dave.Nystrom at tachyonlogic.com> wrote:
> At the end of configure.log, there are two possible ways to build petsc-dev
> that are specified.  Which is the recommended way to build - using make or
> using python?  I have been using make.
> Also, one is labeled as legacy and one is labeled as experimental.  That
> gives the impression of having a choice between an old, archaic method or a
> new, experimental approach.  Should one just be labeled as production?
You do not have CMake, and thus did not get the "production" printout. The
make is
indeed legacy, but just as fast as CMake (Aron), as I believe the Python is
as well.
The Python is experimental, but I have been using it for a year and it
works fine.
   Matt
> Thanks,
> Dave
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120422/aa7527c0/attachment.html>
