[petsc-dev] PCApplyTranspose in BiCG
    Sean Farley
    sean at mcs.anl.gov
    Fri Apr  6 20:58:46 CDT 2012
>   A change in tfqmr that broke it? A change in some underlying thing that
> tfqmr that broke it.
>   The "correct" way to track down the "bad" change is to us bisection with
> mecurial http://www.selenic.com/mercurial/hg.1.html#bisect it lets you
> quickly zoom into the change set that causes the change.
Don't forget that since we don't use subrepositories you'll have to do a
little bit extra to get buildsystem to work:
http://www.mcs.anl.gov/petsc/documentation/faq.html#bisect
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120406/ec1f4120/attachment.html>
