[petsc-dev] PCApplyTranspose in BiCG
    Alexander Grayver
    agrayver at gfz-potsdam.de
    Tue Apr 10 04:47:49 CDT 2012
Barry,
Well, this is not easy to apply bisection here since "good" petsc-dev
had bugs that I patched manually (including Intel MKL BLAS
incompatibility) and only after that I was able to run solver
successfully. "Bad" petsc-dev has all these issues patched and names of
some routines have been changed as well (MatCreateXXX)... However TFQMR
doesn't work at all for any system I tried.
Unfortunately, the shortest time gap between "good" and "bad" I can give
so far is:
HG revision: a4dae06b4d05ef5b78a9a9aa2cbc31b2b158834f HG Date: Wed Feb
08 11:29:52 2012 -0600 --- GOOD
HG revision: 59ca71b85d784abbe22f12c34ffcb2ccc6dc68b0 HG Date: Tue Mar
20 01:05:13 2012 -0500 --- BAD
I tested them like that:
./ex10 -f A.dat -rhs RHS.dat -ksp_type tfqmr -pc_type sor
-ksp_monitor_true_residual -ksp_max_it 500
   95 KSP preconditioned resid norm 2.117351054162e-18 true resid norm
1.981564630346e-15 ||r(i)||/||b|| 3.893342156134e-05   ---- GOOD
500 KSP preconditioned resid norm 3.000274090666e-13 true resid norm
4.577554424627e-11 ||r(i)||/||b|| 8.993895702653e-01   ---- BAD
If it is of any help files are here:
http://dl.dropbox.com/u/60982984/A.dat
http://dl.dropbox.com/u/60982984/RHS.dat
Is this possible to look up changes in one file only?
On 07.04.2012 02:46, Barry Smith wrote:
>     A change in tfqmr that broke it? A change in some underlying thing that tfqmr that broke it.
>     The "correct" way to track down the "bad" change is to us bisection with mecurial http://www.selenic.com/mercurial/hg.1.html#bisect it lets you quickly zoom into the change set that causes the change.
>      Barry
> On Mar 23, 2012, at 3:35 AM, Alexander Grayver wrote:
>> Barry,
>> gmres produces the same result.
>> What does that mean?
>> On 22.03.2012 21:10, Barry Smith wrote:
>>>     Ok, first thing to confirm is if other KSP also produce different results. Run both exactly the same but use -ksp_type gmres on both; does it produce different results or the same?
>>>     Barry
>>> On Mar 22, 2012, at 12:30 PM, Alexander Grayver wrote:
>>>> Jed,
>>>> Ok, I see. Initially I've changed solver because I observed one thing. I have two petsc-dev (one is older than the other) versions compiled.
>>>> Running the same program with both gives different results:
>>>> ./solveTest -ksp_view -ksp_converged_reason -ksp_monitor_true_residual -log_summary -mat_type aij -ksp_rtol 1.0e-7 -ksp_type tfqmr -pc_type sor -ksp_max_it 750
>>>>    0 KSP preconditioned resid norm 9.760858225033e-10 true resid norm 4.108026443997e-08 ||r(i)||/||b|| 1.000000000000e+00
>>>>    1 KSP preconditioned resid norm 9.497939702484e-10 true resid norm 3.591828545356e-08 ||r(i)||/||b|| 8.743440662618e-01
>>>>    1 KSP preconditioned resid norm 1.341212527158e-09 true resid norm 3.754099340764e-08 ||r(i)||/||b|| 9.138449793207e-01
>>>>    2 KSP preconditioned resid norm 9.481744679086e-10 true resid norm 3.710424003325e-08 ||r(i)||/||b|| 9.032132713620e-01
>>>>    2 KSP preconditioned resid norm 1.340878639500e-09 true resid norm 3.730261027312e-08 ||r(i)||/||b|| 9.080421166135e-01
>>>>    3 KSP preconditioned resid norm 9.481415577317e-10 true resid norm 3.725585425324e-08 ||r(i)||/||b|| 9.069039540306e-01
>>>> 750 KSP preconditioned resid norm 1.340874209607e-09 true resid norm 3.726506102951e-08 ||r(i)||/||b|| 9.071280708031e-01
>>>> Linear solve did not converge due to DIVERGED_ITS iterations 750
>>>> KSP Object: 1 MPI processes
>>>>    type: tfqmr
>>>>    maximum iterations=750, initial guess is zero
>>>>    tolerances:  relative=1e-07, absolute=1e-50, divergence=10000
>>>>    left preconditioning
>>>>    using PRECONDITIONED norm type for convergence test
>>>> PC Object: 1 MPI processes
>>>>    type: sor
>>>>      SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
>>>>    linear system matrix = precond matrix:
>>>>    Matrix Object:   1 MPI processes
>>>>      type: seqaij
>>>>      rows=1375920, cols=1375920
>>>>      total: nonzeros=17671714, allocated nonzeros=17671714
>>>>      total number of mallocs used during MatSetValues calls =0
>>>>        not using I-node routines
>>>> Using Petsc Development HG revision: 59ca71b85d784abbe22f12c34ffcb2ccc6dc68b0  HG Date: Tue Mar 20 01:05:13 2012 -0500
>>>> Configure options: --with-petsc-arch=openmpi-intel-complex-release-c --with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2 --with-scalar-type=complex --with-precision=double --with-blas-lapack-dir=/usr/local/lib --with-x=0 --with-debugging=0
>>>> And now second one:
>>>>    0 KSP preconditioned resid norm 9.760858225034e-10 true resid norm 4.108026443997e-08 ||r(i)||/||b|| 1.000000000000e+00
>>>>    1 KSP preconditioned resid norm 9.497930576113e-10 true resid norm 3.591633653854e-08 ||r(i)||/||b|| 8.742966246242e-01
>>>>    1 KSP preconditioned resid norm 1.341211098002e-09 true resid norm 3.754049143693e-08 ||r(i)||/||b|| 9.138327600539e-01
>>>>    2 KSP preconditioned resid norm 9.481662292281e-10 true resid norm 3.709648505700e-08 ||r(i)||/||b|| 9.030244951612e-01
>>>>    2 KSP preconditioned resid norm 1.340863953080e-09 true resid norm 3.730358317575e-08 ||r(i)||/||b|| 9.080657995827e-01
>>>>    3 KSP preconditioned resid norm 9.481308142928e-10 true resid norm 3.725036905334e-08 ||r(i)||/||b|| 9.067704300630e-01
>>>> 230 KSP preconditioned resid norm 8.875661094394e-17 true resid norm 1.062030983067e-14 ||r(i)||/||b|| 2.585258389996e-07
>>>> Linear solve converged due to CONVERGED_RTOL iterations 230
>>>>    type: tfqmr
>>>>    type: sor
>>>>      type: seqaij
>>>> Using Petsc Development HG revision: a4dae06b4d05ef5b78a9a9aa2cbc31b2b158834f  HG Date: Wed Feb 08 11:29:52 2012 -0600
>>>> Configure options: --with-petsc-arch=openmpi-intel-complex-release-f-mkl --with-fortran-interfaces=1 --download-superlu --download-superlu_dist --download-mumps --download-parmetis --download-ptscotch --download-metis --with-scalapack-lib=/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_scalapack_lp64.a --with-scalapack-include=/opt/intel/Compiler/11.1/072/mkl/include --with-blacs-lib=/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_blacs_openmpi_lp64.a --with-blacs-include=/opt/intel/Compiler/11.1/072/mkl/include --with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2 --with-scalar-type=complex --with-blas-lapack-lib="[/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_intel_lp64.a,/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_intel_thread.a,/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_core.a,/opt/intel/Compiler/11.1/072/lib/intel64/libiomp5.a]" --with-precision=double --with-x=0 --with-debugging=0
>>>> Well, two version compiled with different lines, but still I don't think this is the reason...
>>>> Where actually to look at?
>>>> Thanks.
>>>> On 22.03.2012 15:42, Jed Brown wrote:
>>>>> On Thu, Mar 22, 2012 at 04:23, Alexander Grayver<agrayver at gfz-potsdam.de>   wrote:
>>>>> I've got the following error when applying bicg+sor to my problem:
>>>>> mt-soft/solveTest>   ./solveTest -ksp_view -ksp_converged_reason -ksp_monitor_true_residual -log_summary -mat_type aij -ksp_rtol 1.0e-7 -ksp_type bicg -pc_type sor -ksp_max_it 750
>>>>> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
>>>>> [0]PETSC ERROR: No support for this operation for this object type!
>>>>> [0]PETSC ERROR: PC does not have apply transpose!
>>>>> [0]PETSC ERROR: ------------------------------------------------------------------------
>>>>> [0]PETSC ERROR: Petsc Development HG revision: 59ca71b85d784abbe22f12c34ffcb2ccc6dc68b0  HG Date: Tue Mar 20 01:05:13 2012 -0500
>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>> [0]PETSC ERROR: Configure options --with-petsc-arch=openmpi-intel-complex-release-c --with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2 --with-scalar-type=complex --with-precision=double --with-blas-lapack-dir=/usr/local/lib --with-x=0 --with-debugging=0
>>>>> [0]PETSC ERROR: PCApplyTranspose() line 515 in /home/mt/agrayver/lib/petsc-dev/src/ksp/pc/interface/precon.c
>>>>> [0]PETSC ERROR: KSPSolve_BiCG() line 55 in /home/mt/agrayver/lib/petsc-dev/src/ksp/ksp/impls/bicg/bicg.c
>>>>> [0]PETSC ERROR: KSPSolve() line 434 in /home/mt/agrayver/lib/petsc-dev/src/ksp/ksp/interface/itfunc.c
>>>>> [0]PETSC ERROR: main() line 114 in /home/solveTest.c
>>>>> Any ideas?
>>>>> PCApplyTranspose_SOR is not implemented. It is unfortunately not an operation that is efficient to implement in-place like SOR.
>>>> Regards,
>>>> Alexander
>> Regards,
>> Alexander
Alexander
