[petsc-dev] ssl required when pushing
    Jed Brown
    jedbrown at mcs.anl.gov
    Tue Apr  3 08:23:43 CDT 2012
On Tue, Apr 3, 2012 at 02:44, Stefano Zampini <stefano.zampini at gmail.com>wrote:
> after a while, I was trying to push some changes for BDDC code on
> http://petsc.cs.iit.edu.
> I got the following hg error : ssl required.
> Is it a problem I need to investigate on my side or did you remove my
> writing permissions on http://petsc.cs.iit.edu/petsc-dev?
> Some times ago I erroneously pushed to bitbucket and you removed my
> permissions.
Pushing via http is never supported, pushing via https is not supported on
petsc.cs.iit.edu. You should use ssh://
petsc at petsc.cs.iit.edu//hg/petsc/petsc-dev
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120403/2378ae4f/attachment.html>
