[petsc-dev] ssl required when pushing
    Stefano Zampini
    stefano.zampini at gmail.com
    Tue Apr  3 04:44:20 CDT 2012
after a while, I was trying to push some changes for BDDC code on
http://petsc.cs.iit.edu.
I got the following hg error : ssl required.
Is it a problem I need to investigate on my side or did you remove my
writing permissions on http://petsc.cs.iit.edu/petsc-dev?
Some times ago I erroneously pushed to bitbucket and you removed my
permissions.
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120403/39fd351c/attachment.html>
