[petsc-dev] ssl required when pushing
    Stefano Zampini
    stefano.zampini at gmail.com
    Tue Apr  3 08:35:26 CDT 2012
My fault. I wrongly renamed the path in $PETSC_DIR/.hg/hgrc after testing
for bitbucket.
Pushed.
Thank you,
Stefano
2012/4/3 Jed Brown <jedbrown at mcs.anl.gov>
> On Tue, Apr 3, 2012 at 02:44, Stefano Zampini <stefano.zampini at gmail.com>wrote:
>> after a while, I was trying to push some changes for BDDC code on
>> http://petsc.cs.iit.edu.
>> I got the following hg error : ssl required.
>> Is it a problem I need to investigate on my side or did you remove my
>> writing permissions on http://petsc.cs.iit.edu/petsc-dev?
>> Some times ago I erroneously pushed to bitbucket and you removed my
>> permissions.
> Pushing via http is never supported, pushing via https is not supported on
> petsc.cs.iit.edu. You should use ssh://
> petsc at petsc.cs.iit.edu//hg/petsc/petsc-dev
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120403/28b0673b/attachment.html>
