[petsc-dev] How do you get RIchardson?
    Matthew Knepley
    knepley at gmail.com
    Fri Sep 16 16:00:59 CDT 2011
On Fri, Sep 16, 2011 at 3:58 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Fri, Sep 16, 2011 at 22:42, Matthew Knepley <knepley at gmail.com> wrote:
>> It is of course a fixed point iteration, and your definition of Picard is
>> a classic logical
>> fallacy. This is a valid fixed point iteration, Picard refers to a fixed
>> point iteration,
>> therefore all Picard iterations are of this form. In fact, Picard
>> encompasses fixed
>> point iteration to solve nonlinear equations.
> I did not assert that it was the _only_ Picard, merely that it is the
> Picard used in practice to solve nonlinear differential equations. In naming
> SNESPICARD, you made a different choice, at least as valid in mathematical
> purity, but not the fixed point iteration commonly used to solve nonlinear
> differential equations. I don't understand why you are so enamored with that
> name.
It is the name for this generic concept:
  Solve F(u) = 0, by successive approximations u^{n+1} = F(u^n)
There is no other name for this process, and the proper name is the Picard
Iteration. I do not know why
you have such a hard time with historically accurate naming.
    Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110916/a3298b85/attachment.html>
