[petsc-dev] VecGetArrayF90 without finclude/petscvec.h90
    Jed Brown
    jedbrown at mcs.anl.gov
    Sat Sep 10 08:45:42 CDT 2011
If you forget to include this header, there are no warnings, but the array
pointer shows up as NULL on the C side (currently causing a seg-fault). Is
there a way to check for this at compile time?
I just lost some time tracking this down, so we need some sort of a check.
It's trivial to do at run-time, though I don't know if having the pointer
show up as NULL is a gfortran artifact or something more general.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110910/8cfa4f08/attachment.html>
