[petsc-dev] Fwd: petsc-dev like totally broken?
Barry Smith
bsmith at mcs.anl.gov
Fri Sep 9 19:48:15 CDT 2011
On Sep 9, 2011, at 5:06 PM, Satish Balay wrote:
> my petsc-dev build ran fine on the Mac.
> What configure options do you use for your build?
> Perhaps something in your ~/.petscrc is triggering this error?
This all happened at the public library, now that I am home it runs fine. My guess is some weird network thing that didn't affect OpenMPI.
barry
> Satish
> balay at petsc-mini: mpich2-1.4.1p1>grep -r "Invalid error class" .
> ./src/mpi/errhan/errutil.c: MPIU_Error_printf("INTERNAL ERROR: Invalid error class (%d) encountered while returning from\n"
> On Fri, 9 Sep 2011, Satish Balay wrote:
>> petsc32 [and dev] should be using latest mpich2-1.4.1p1. Nightly
>> builds on Mac were fine [last I checked before release]
>> Will check petsc-dev on petsc-mini
>> Satish
>> On Fri, 9 Sep 2011, Barry Smith wrote:
>>> Rebooted machine, made no difference. Built with --download-openmpi works like a charm.
>>> Did someone upgrade the --download-mpich tarball without testing it? Any other changes like that?
>>> Thanks
>>> Barry
>>> Begin forwarded message:
>>>> From: Barry Smith <bsmith at mcs.anl.gov>
>>>> Date: September 9, 2011 4:05:23 PM CDT
>>>> To: For users of the development version of PETSc <petsc-dev at mcs.anl.gov>
>>>> Subject: petsc-dev like totally broken?
>>>> Fresh pull of petsc-dev and BuildSystem
>>>> Removed externalpackages and $PETSC_ARCH, ran an entirely new configure with --download-mpich
>>>> Parallel runs to not work, after hanging a long time it gives
>>>> internal:petsc-dev barrysmith$ make test
>>>> Running test examples to verify correct installation
>>>> C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1 MPI process
>>>> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2 MPI processes
>>>> See http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html
>>>> INTERNAL ERROR: Invalid error class (66) encountered while returning from
>>>> MPI_Bcast. Please file a bug report.
>>>> [0]PETSC ERROR: PetscOptionsInsertFile() line 462 in /Users/barrysmith/Src/petsc-dev/src/sys/objects/options.c
>>>> [0]PETSC ERROR: PetscOptionsInsert() line 617 in /Users/barrysmith/Src/petsc-dev/src/sys/objects/options.c
>>>> [0]PETSC ERROR: PetscInitialize() line 758 in /Users/barrysmith/Src/petsc-dev/src/sys/objects/pinit.c
>>>> Completed test examples
>>>> Any ideas?
