[petsc-dev] VecGetArrayF90 without finclude/petscvec.h90
    Barry Smith
    bsmith at mcs.anl.gov
    Sat Sep 10 09:08:18 CDT 2011
On Sep 10, 2011, at 8:45 AM, Jed Brown wrote:
> If you forget to include this header, there are no warnings, but the array pointer shows up as NULL on the C side (currently causing a seg-fault). Is there a way to check for this at compile time?
   Is ptr null or *ptr? It seems to mean checking for the nullness on the C side is better than nothing even if it doesn't always work.
    Barry
> I just lost some time tracking this down, so we need some sort of a check. It's trivial to do at run-time, though I don't know if having the pointer show up as NULL is a gfortran artifact or something more general.
