[petsc-dev] Fwd: petsc-dev like totally broken?
Fri Sep 9 17:06:39 CDT 2011
my petsc-dev build ran fine on the Mac.
What configure options do you use for your build?
Perhaps something in your ~/.petscrc is triggering this error?
Satish
balay at petsc-mini: mpich2-1.4.1p1>grep -r "Invalid error class" .
./src/mpi/errhan/errutil.c:               MPIU_Error_printf("INTERNAL ERROR: Invalid error class (%d) encountered while returning from\n"
On Fri, 9 Sep 2011, Satish Balay wrote:
> petsc32 [and dev] should be using latest mpich2-1.4.1p1. Nightly
> builds on Mac were fine [last I checked before release]
> Will check petsc-dev on petsc-mini
> Satish
> On Fri, 9 Sep 2011, Barry Smith wrote:
> >    Rebooted machine, made no difference. Built with --download-openmpi works like a charm.
> >     Did someone upgrade the --download-mpich tarball without testing it? Any other changes like that?
> >    Thanks
> >    Barry
> > Begin forwarded message:
> > > From: Barry Smith <bsmith at mcs.anl.gov>
> > > Date: September 9, 2011 4:05:23 PM CDT
> > > To: For users of the development version of PETSc <petsc-dev at mcs.anl.gov>
> > > Subject: petsc-dev like totally broken?
> > >   Fresh pull of petsc-dev and BuildSystem
> > >   Removed externalpackages and $PETSC_ARCH, ran an entirely new configure with --download-mpich
> > >   Parallel runs to not work, after hanging a long time it gives
> > > internal:petsc-dev barrysmith$ make test
> > > Running test examples to verify correct installation
> > > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1 MPI process
> > > Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2 MPI processes
> > > See http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html
> > > INTERNAL ERROR: Invalid error class (66) encountered while returning from
> > > MPI_Bcast.  Please file a bug report.
> > > [0]PETSC ERROR: PetscOptionsInsertFile() line 462 in /Users/barrysmith/Src/petsc-dev/src/sys/objects/options.c
> > > [0]PETSC ERROR: PetscOptionsInsert() line 617 in /Users/barrysmith/Src/petsc-dev/src/sys/objects/options.c
> > > [0]PETSC ERROR: PetscInitialize() line 758 in /Users/barrysmith/Src/petsc-dev/src/sys/objects/pinit.c
> > > Completed test examples
> > >  Any ideas?
