[petsc-dev] Fwd: petsc-dev like totally broken?
    Satish Balay
    balay at mcs.anl.gov
    Fri Sep  9 16:30:38 CDT 2011
petsc32 [and dev] should be using latest mpich2-1.4.1p1. Nightly
builds on Mac were fine [last I checked before release]
Will check petsc-dev on petsc-mini
Satish
On Fri, 9 Sep 2011, Barry Smith wrote:
>    Rebooted machine, made no difference. Built with --download-openmpi works like a charm.
>     Did someone upgrade the --download-mpich tarball without testing it? Any other changes like that?
>    Thanks
>    Barry
> Begin forwarded message:
> > From: Barry Smith <bsmith at mcs.anl.gov>
> > Date: September 9, 2011 4:05:23 PM CDT
> > To: For users of the development version of PETSc <petsc-dev at mcs.anl.gov>
> > Subject: petsc-dev like totally broken?
> >   Fresh pull of petsc-dev and BuildSystem
> >   Removed externalpackages and $PETSC_ARCH, ran an entirely new configure with --download-mpich
> >   Parallel runs to not work, after hanging a long time it gives
> > internal:petsc-dev barrysmith$ make test
> > Running test examples to verify correct installation
> > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1 MPI process
> > Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2 MPI processes
> > See http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html
> > INTERNAL ERROR: Invalid error class (66) encountered while returning from
> > MPI_Bcast.  Please file a bug report.
> > [0]PETSC ERROR: PetscOptionsInsertFile() line 462 in /Users/barrysmith/Src/petsc-dev/src/sys/objects/options.c
> > [0]PETSC ERROR: PetscOptionsInsert() line 617 in /Users/barrysmith/Src/petsc-dev/src/sys/objects/options.c
> > [0]PETSC ERROR: PetscInitialize() line 758 in /Users/barrysmith/Src/petsc-dev/src/sys/objects/pinit.c
> > Completed test examples
> >  Any ideas?
