[petsc-dev] Fwd: petsc-dev like totally broken?
Barry Smith
bsmith at mcs.anl.gov
Fri Sep 9 16:25:42 CDT 2011
Rebooted machine, made no difference. Built with --download-openmpi works like a charm.
Did someone upgrade the --download-mpich tarball without testing it? Any other changes like that?
Thanks
Barry
Begin forwarded message:
> From: Barry Smith <bsmith at mcs.anl.gov>
> Date: September 9, 2011 4:05:23 PM CDT
> To: For users of the development version of PETSc <petsc-dev at mcs.anl.gov>
> Subject: petsc-dev like totally broken?
> Fresh pull of petsc-dev and BuildSystem
> Removed externalpackages and $PETSC_ARCH, ran an entirely new configure with --download-mpich
> Parallel runs to not work, after hanging a long time it gives
> internal:petsc-dev barrysmith$ make test
> Running test examples to verify correct installation
> C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1 MPI process
> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2 MPI processes
> See http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html
> INTERNAL ERROR: Invalid error class (66) encountered while returning from
> MPI_Bcast. Please file a bug report.
> [0]PETSC ERROR: PetscOptionsInsertFile() line 462 in /Users/barrysmith/Src/petsc-dev/src/sys/objects/options.c
> [0]PETSC ERROR: PetscOptionsInsert() line 617 in /Users/barrysmith/Src/petsc-dev/src/sys/objects/options.c
> [0]PETSC ERROR: PetscInitialize() line 758 in /Users/barrysmith/Src/petsc-dev/src/sys/objects/pinit.c
> Completed test examples
> Any ideas?
