[petsc-dev] petsc-dev like totally broken?
    Barry Smith
    bsmith at mcs.anl.gov
    Fri Sep  9 16:05:23 CDT 2011
   Fresh pull of petsc-dev and BuildSystem
   Removed externalpackages and $PETSC_ARCH, ran an entirely new configure with --download-mpich
   Parallel runs to not work, after hanging a long time it gives
internal:petsc-dev barrysmith$ make test
Running test examples to verify correct installation
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1 MPI process
Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2 MPI processes
See http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html
INTERNAL ERROR: Invalid error class (66) encountered while returning from
MPI_Bcast.  Please file a bug report.
[0]PETSC ERROR: PetscOptionsInsertFile() line 462 in /Users/barrysmith/Src/petsc-dev/src/sys/objects/options.c
[0]PETSC ERROR: PetscOptionsInsert() line 617 in /Users/barrysmith/Src/petsc-dev/src/sys/objects/options.c
[0]PETSC ERROR: PetscInitialize() line 758 in /Users/barrysmith/Src/petsc-dev/src/sys/objects/pinit.c
Completed test examples
  Any ideas?
