[petsc-dev] BuildSystem Docs
Matthew Knepley
knepley at gmail.com
Thu Sep 8 18:44:49 CDT 2011
On Thu, Sep 8, 2011 at 6:12 PM, Ward, Duane L <Duane.Ward at pnnl.gov> wrote:
> I’m looking into using the PETSc BuildSystem for software other than
> PETSc. This system seems to have a lot of functionality but I’m having some
> difficulty in figuring out what is needed to write a new module for use with
> BuildSystem. I tried building the docs but didn’t have much luck. Is there
> another place where I could grab the documentation on BuildSystem?
Did you read the documentation at the top of the source files, start with
framework.py and base.py.
It is somewhat long and fairly specific. I also made a minimal configure
example:
http://petsc.cs.iit.edu/petsc/simpleConfigure/
Matt
> Thanks for any help you can provide,
> Duane
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110908/59ad6f9f/attachment.html>
