[petsc-dev] BuildSystem Docs
    Ward, Duane L
    Duane.Ward at pnnl.gov
    Thu Sep  8 18:12:46 CDT 2011
I'm looking into using the PETSc BuildSystem for software other than PETSc.  This system seems to have a lot of functionality but I'm having some difficulty in figuring out what is needed to write a new module for use with BuildSystem.  I tried building the docs but didn't have much luck.  Is there another place where I could grab the documentation on BuildSystem?
Thanks for any help you can provide,
Duane
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110908/a7bdafae/attachment.html>
