[petsc-dev] Binary test files in $PETSC_DIR/include ?
    Lisandro Dalcin
    dalcinl at gmail.com
    Mon Sep  5 23:03:07 CDT 2011
On 6 September 2011 00:44, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Sep 5, 2011, at 10:36 PM, Lisandro Dalcin wrote:
>> On 5 September 2011 22:56, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> On Sep 5, 2011, at 8:52 PM, Lisandro Dalcin wrote:
>>>> Barry, did you really meant to add these files in $PETSC_DIR/include ?
>>>  Yes, is this a problem?
>> Well, I usually think of */include as a place to put header files.
>  I'm happy to put them some other "standard" place if there is such a thing. I stuck them in include because that contains non-generated stuff while lib contains generated stuff.
If you want them available for a prefix install, the root of such
"standard" place could be "<prefix>/share/petsc", so you should use
"<prefix>/share/petsc/datafiles".
>   Barry
>>>   Where are you getting them listed as changed?  They should never be changed.
>> No, no.. Just wanted to make sure these files were not added (in that
>> place) by mistake.
>>>> [dalcinl at trantor petsc-3.2]$ hg show paths.default
>>>> ssh://petsc@petsc.cs.iit.edu//hg/petsc/releases/petsc-3.2
>>>> [dalcinl at trantor petsc-3.2]$ hg log -p include/datafiles/matrices/
>>>> changeset:   20128:497567453eac
>>>> parent:      20118:944e41e7f798
>>>> user:        Barry Smith <bsmith at mcs.anl.gov>
>>>> date:        Mon Aug 29 20:49:00 2011 -0500
>>>> summary:     added test files
>>>> diff -r 944e41e7f798 -r 497567453eac
>>>> include/datafiles/matrices/hpd-complex-int32-float32
>>>> Binary file include/datafiles/matrices/hpd-complex-int32-float32 has changed
>>>> include/datafiles/matrices/hpd-complex-int32-float64
>>>> Binary file include/datafiles/matrices/hpd-complex-int32-float64 has changed
>>>> include/datafiles/matrices/hpd-complex-int64-float32
>>>> Binary file include/datafiles/matrices/hpd-complex-int64-float32 has changed
>>>> include/datafiles/matrices/hpd-complex-int64-float64
>>>> Binary file include/datafiles/matrices/hpd-complex-int64-float64 has changed
>>>> include/datafiles/matrices/nh-complex-int32-float32
>>>> Binary file include/datafiles/matrices/nh-complex-int32-float32 has changed
>>>> include/datafiles/matrices/nh-complex-int32-float64
>>>> Binary file include/datafiles/matrices/nh-complex-int32-float64 has changed
>>>> include/datafiles/matrices/nh-complex-int64-float32
>>>> Binary file include/datafiles/matrices/nh-complex-int64-float32 has changed
>>>> include/datafiles/matrices/nh-complex-int64-float64
>>>> Binary file include/datafiles/matrices/nh-complex-int64-float64 has changed
>>>> include/datafiles/matrices/ns-real-int32-float32
>>>> Binary file include/datafiles/matrices/ns-real-int32-float32 has changed
>>>> include/datafiles/matrices/ns-real-int32-float64
>>>> Binary file include/datafiles/matrices/ns-real-int32-float64 has changed
>>>> include/datafiles/matrices/ns-real-int64-float32
>>>> Binary file include/datafiles/matrices/ns-real-int64-float32 has changed
>>>> include/datafiles/matrices/ns-real-int64-float64
>>>> Binary file include/datafiles/matrices/ns-real-int64-float64 has changed
>>>> include/datafiles/matrices/spd-real-int32-float32
>>>> Binary file include/datafiles/matrices/spd-real-int32-float32 has changed
>>>> include/datafiles/matrices/spd-real-int32-float64
>>>> Binary file include/datafiles/matrices/spd-real-int32-float64 has changed
>>>> include/datafiles/matrices/spd-real-int64-float32
>>>> Binary file include/datafiles/matrices/spd-real-int64-float32 has changed
>>>> include/datafiles/matrices/spd-real-int64-float64
>>>> Binary file include/datafiles/matrices/spd-real-int64-float64 has changed
>>>> Lisandro Dalcin
>>>> CIMEC (INTEC/CONICET-UNL)
>>>> Predio CONICET-Santa Fe
>>>> Colectora RN 168 Km 472, Paraje El Pozo
>>>> 3000 Santa Fe, Argentina
>>>> Tel: +54-342-4511594 (ext 1011)
>>>> Tel/Fax: +54-342-4511169
>> Lisandro Dalcin
Lisandro Dalcin
