[petsc-dev] Binary test files in $PETSC_DIR/include ?
Barry Smith
bsmith at mcs.anl.gov
Tue Sep 6 07:37:14 CDT 2011
On Sep 5, 2011, at 11:03 PM, Lisandro Dalcin wrote:
> On 6 September 2011 00:44, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Sep 5, 2011, at 10:36 PM, Lisandro Dalcin wrote:
>>> On 5 September 2011 22:56, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> On Sep 5, 2011, at 8:52 PM, Lisandro Dalcin wrote:
>>>>> Barry, did you really meant to add these files in $PETSC_DIR/include ?
>>>> Yes, is this a problem?
>>> Well, I usually think of */include as a place to put header files.
>> I'm happy to put them some other "standard" place if there is such a thing. I stuck them in include because that contains non-generated stuff while lib contains generated stuff.
> If you want them available for a prefix install, the root of such
> "standard" place could be "<prefix>/share/petsc", so you should use
> "<prefix>/share/petsc/datafiles".
Ok, where do I put them in the PETSc tree in a corresponding place? I can do ${PETSC_DIR}/share/datafiles or ${PETSC_DIR}/share/petsc/datafiles but that looks weird but I guess weird is in.
Barry
>> Barry
>>>> Where are you getting them listed as changed? They should never be changed.
>>> No, no.. Just wanted to make sure these files were not added (in that
>>> place) by mistake.
>>>>> [dalcinl at trantor petsc-3.2]$ hg show paths.default
>>>>> ssh://petsc@petsc.cs.iit.edu//hg/petsc/releases/petsc-3.2
>>>>> [dalcinl at trantor petsc-3.2]$ hg log -p include/datafiles/matrices/
>>>>> changeset: 20128:497567453eac
>>>>> parent: 20118:944e41e7f798
>>>>> user: Barry Smith <bsmith at mcs.anl.gov>
>>>>> date: Mon Aug 29 20:49:00 2011 -0500
>>>>> summary: added test files
>>>>> diff -r 944e41e7f798 -r 497567453eac
>>>>> include/datafiles/matrices/hpd-complex-int32-float32
>>>>> Binary file include/datafiles/matrices/hpd-complex-int32-float32 has changed
>>>>> include/datafiles/matrices/hpd-complex-int32-float64
>>>>> Binary file include/datafiles/matrices/hpd-complex-int32-float64 has changed
>>>>> include/datafiles/matrices/hpd-complex-int64-float32
>>>>> Binary file include/datafiles/matrices/hpd-complex-int64-float32 has changed
>>>>> include/datafiles/matrices/hpd-complex-int64-float64
>>>>> Binary file include/datafiles/matrices/hpd-complex-int64-float64 has changed
>>>>> include/datafiles/matrices/nh-complex-int32-float32
>>>>> Binary file include/datafiles/matrices/nh-complex-int32-float32 has changed
>>>>> include/datafiles/matrices/nh-complex-int32-float64
>>>>> Binary file include/datafiles/matrices/nh-complex-int32-float64 has changed
>>>>> include/datafiles/matrices/nh-complex-int64-float32
>>>>> Binary file include/datafiles/matrices/nh-complex-int64-float32 has changed
>>>>> include/datafiles/matrices/nh-complex-int64-float64
>>>>> Binary file include/datafiles/matrices/nh-complex-int64-float64 has changed
>>>>> include/datafiles/matrices/ns-real-int32-float32
>>>>> Binary file include/datafiles/matrices/ns-real-int32-float32 has changed
>>>>> include/datafiles/matrices/ns-real-int32-float64
>>>>> Binary file include/datafiles/matrices/ns-real-int32-float64 has changed
>>>>> include/datafiles/matrices/ns-real-int64-float32
>>>>> Binary file include/datafiles/matrices/ns-real-int64-float32 has changed
>>>>> include/datafiles/matrices/ns-real-int64-float64
>>>>> Binary file include/datafiles/matrices/ns-real-int64-float64 has changed
>>>>> include/datafiles/matrices/spd-real-int32-float32
>>>>> Binary file include/datafiles/matrices/spd-real-int32-float32 has changed
>>>>> include/datafiles/matrices/spd-real-int32-float64
>>>>> Binary file include/datafiles/matrices/spd-real-int32-float64 has changed
>>>>> include/datafiles/matrices/spd-real-int64-float32
>>>>> Binary file include/datafiles/matrices/spd-real-int64-float32 has changed
>>>>> include/datafiles/matrices/spd-real-int64-float64
>>>>> Binary file include/datafiles/matrices/spd-real-int64-float64 has changed
>>>>> Lisandro Dalcin
>>>>> CIMEC (INTEC/CONICET-UNL)
>>>>> Predio CONICET-Santa Fe
>>>>> Colectora RN 168 Km 472, Paraje El Pozo
>>>>> 3000 Santa Fe, Argentina
>>>>> Tel: +54-342-4511594 (ext 1011)
>>>>> Tel/Fax: +54-342-4511169
>>> Lisandro Dalcin
> Lisandro Dalcin
