[petsc-dev] Binary test files in $PETSC_DIR/include ?
    Lisandro Dalcin
    dalcinl at gmail.com
    Mon Sep  5 22:36:13 CDT 2011
On 5 September 2011 22:56, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Sep 5, 2011, at 8:52 PM, Lisandro Dalcin wrote:
>> Barry, did you really meant to add these files in $PETSC_DIR/include ?
>  Yes, is this a problem?
Well, I usually think of */include as a place to put header files.
>   Where are you getting them listed as changed?  They should never be changed.
No, no.. Just wanted to make sure these files were not added (in that
place) by mistake.
>> [dalcinl at trantor petsc-3.2]$ hg show paths.default
>> ssh://petsc@petsc.cs.iit.edu//hg/petsc/releases/petsc-3.2
>> [dalcinl at trantor petsc-3.2]$ hg log -p include/datafiles/matrices/
>> changeset:   20128:497567453eac
>> parent:      20118:944e41e7f798
>> user:        Barry Smith <bsmith at mcs.anl.gov>
>> date:        Mon Aug 29 20:49:00 2011 -0500
>> summary:     added test files
>> diff -r 944e41e7f798 -r 497567453eac
>> include/datafiles/matrices/hpd-complex-int32-float32
>> Binary file include/datafiles/matrices/hpd-complex-int32-float32 has changed
>> include/datafiles/matrices/hpd-complex-int32-float64
>> Binary file include/datafiles/matrices/hpd-complex-int32-float64 has changed
>> include/datafiles/matrices/hpd-complex-int64-float32
>> Binary file include/datafiles/matrices/hpd-complex-int64-float32 has changed
>> include/datafiles/matrices/hpd-complex-int64-float64
>> Binary file include/datafiles/matrices/hpd-complex-int64-float64 has changed
>> include/datafiles/matrices/nh-complex-int32-float32
>> Binary file include/datafiles/matrices/nh-complex-int32-float32 has changed
>> include/datafiles/matrices/nh-complex-int32-float64
>> Binary file include/datafiles/matrices/nh-complex-int32-float64 has changed
>> include/datafiles/matrices/nh-complex-int64-float32
>> Binary file include/datafiles/matrices/nh-complex-int64-float32 has changed
>> include/datafiles/matrices/nh-complex-int64-float64
>> Binary file include/datafiles/matrices/nh-complex-int64-float64 has changed
>> include/datafiles/matrices/ns-real-int32-float32
>> Binary file include/datafiles/matrices/ns-real-int32-float32 has changed
>> include/datafiles/matrices/ns-real-int32-float64
>> Binary file include/datafiles/matrices/ns-real-int32-float64 has changed
>> include/datafiles/matrices/ns-real-int64-float32
>> Binary file include/datafiles/matrices/ns-real-int64-float32 has changed
>> include/datafiles/matrices/ns-real-int64-float64
>> Binary file include/datafiles/matrices/ns-real-int64-float64 has changed
>> include/datafiles/matrices/spd-real-int32-float32
>> Binary file include/datafiles/matrices/spd-real-int32-float32 has changed
>> include/datafiles/matrices/spd-real-int32-float64
>> Binary file include/datafiles/matrices/spd-real-int32-float64 has changed
>> include/datafiles/matrices/spd-real-int64-float32
>> Binary file include/datafiles/matrices/spd-real-int64-float32 has changed
>> include/datafiles/matrices/spd-real-int64-float64
>> Binary file include/datafiles/matrices/spd-real-int64-float64 has changed
>> Lisandro Dalcin
>> CIMEC (INTEC/CONICET-UNL)
>> Predio CONICET-Santa Fe
>> Colectora RN 168 Km 472, Paraje El Pozo
>> 3000 Santa Fe, Argentina
>> Tel: +54-342-4511594 (ext 1011)
>> Tel/Fax: +54-342-4511169
Lisandro Dalcin
