[petsc-dev] Binary test files in $PETSC_DIR/include ?
    Barry Smith
    bsmith at mcs.anl.gov
    Mon Sep  5 20:56:16 CDT 2011
On Sep 5, 2011, at 8:52 PM, Lisandro Dalcin wrote:
> Barry, did you really meant to add these files in $PETSC_DIR/include ?
  Yes, is this a problem?
   Where are you getting them listed as changed?  They should never be changed.
   Barry
> [dalcinl at trantor petsc-3.2]$ hg show paths.default
> ssh://petsc@petsc.cs.iit.edu//hg/petsc/releases/petsc-3.2
> [dalcinl at trantor petsc-3.2]$ hg log -p include/datafiles/matrices/
> changeset:   20128:497567453eac
> parent:      20118:944e41e7f798
> user:        Barry Smith <bsmith at mcs.anl.gov>
> date:        Mon Aug 29 20:49:00 2011 -0500
> summary:     added test files
> diff -r 944e41e7f798 -r 497567453eac
> include/datafiles/matrices/hpd-complex-int32-float32
> Binary file include/datafiles/matrices/hpd-complex-int32-float32 has changed
> include/datafiles/matrices/hpd-complex-int32-float64
> Binary file include/datafiles/matrices/hpd-complex-int32-float64 has changed
> include/datafiles/matrices/hpd-complex-int64-float32
> Binary file include/datafiles/matrices/hpd-complex-int64-float32 has changed
> include/datafiles/matrices/hpd-complex-int64-float64
> Binary file include/datafiles/matrices/hpd-complex-int64-float64 has changed
> include/datafiles/matrices/nh-complex-int32-float32
> Binary file include/datafiles/matrices/nh-complex-int32-float32 has changed
> include/datafiles/matrices/nh-complex-int32-float64
> Binary file include/datafiles/matrices/nh-complex-int32-float64 has changed
> include/datafiles/matrices/nh-complex-int64-float32
> Binary file include/datafiles/matrices/nh-complex-int64-float32 has changed
> include/datafiles/matrices/nh-complex-int64-float64
> Binary file include/datafiles/matrices/nh-complex-int64-float64 has changed
> include/datafiles/matrices/ns-real-int32-float32
> Binary file include/datafiles/matrices/ns-real-int32-float32 has changed
> include/datafiles/matrices/ns-real-int32-float64
> Binary file include/datafiles/matrices/ns-real-int32-float64 has changed
> include/datafiles/matrices/ns-real-int64-float32
> Binary file include/datafiles/matrices/ns-real-int64-float32 has changed
> include/datafiles/matrices/ns-real-int64-float64
> Binary file include/datafiles/matrices/ns-real-int64-float64 has changed
> include/datafiles/matrices/spd-real-int32-float32
> Binary file include/datafiles/matrices/spd-real-int32-float32 has changed
> include/datafiles/matrices/spd-real-int32-float64
> Binary file include/datafiles/matrices/spd-real-int32-float64 has changed
> include/datafiles/matrices/spd-real-int64-float32
> Binary file include/datafiles/matrices/spd-real-int64-float32 has changed
> include/datafiles/matrices/spd-real-int64-float64
> Binary file include/datafiles/matrices/spd-real-int64-float64 has changed
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> 3000 Santa Fe, Argentina
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
