[petsc-dev] rebase question
Mon Sep 5 11:57:57 CDT 2011
On Mon, Sep 5, 2011 at 18:46, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    This is a bullshit command and doesn't do what it should do.  It checks
> the buffer every certain amount of time and reverts if it finds the file is
> changed. Useless if the file change happened after the last check, when it
> reverts to the same annoying message.
Oh, simple. Just
(setq auto-revert-interval 0.1)
If you do that, it should be pretty rare to visit a file that has not been
auto-reverted yet. There couldn't possibly be a problem with stat'ing 1000
buffers 10 times per second, could there?
This is really disgusting. We should write a new editor that doesn't suck.
;-D
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110905/448f9111/attachment.html>
