[petsc-dev] rebase question
Barry Smith
bsmith at mcs.anl.gov
Mon Sep 5 11:46:24 CDT 2011
On Sep 4, 2011, at 10:48 PM, Sean Farley wrote:
> It bugs the heck out of me that hg "edits" files that I have committed and then did a hg rebase with, so that next time I try to edit in my Emacs buffer it asks me if I "really want to edit the buffer". Of course it wants me to type yes or no but I'm busy typing away and this destroys my train of thought.
> Isn't there an Emacs setting to automatically answer 'yes' or 'no'? After googling:
> (global-auto-revert-mode t)
This is a bullshit command and doesn't do what it should do. It checks the buffer every certain amount of time and reverts if it finds the file is changed. Useless if the file change happened after the last check, when it reverts to the same annoying message.
> What's up with this behavior and is there some way to prevent it; it makes rebase too painful to consider.
> Ok, one, "too painful to consider?" Really? Come on now, just have Emacs auto-load from disk. If a file gets loaded from disk that you didn't want reloaded, then you should still have the previous version in an 'undo' buffer. Two, I've talked with Jed about this, and it occurs because of the way that mercurial does rebasing on the working directory instead of just on the metadata. The "right" way to fix this would be to submit a patch to the mercurial guys that does a rebase on the metadata (and not the working directory). Perhaps after Jed gets back from Zurich, we could force him to write it. I'll have to hide his climbing gear as ransom, though.
> Sean
