[petsc-dev] TSSolve() shouldn't return a time
Matthew Knepley
knepley at gmail.com
Sun Oct 23 15:58:08 CDT 2011
On Sun, Oct 23, 2011 at 8:54 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Sun, Oct 23, 2011 at 15:46, Matthew Knepley <knepley at gmail.com> wrote:
>> This seems like a confusion between the continuum level and the discrete
>> level.
> The TS interface takes a _semidiscrete_ form. It is responsible for the
> discretization in time and it is convenient for the user to think about the
> problem as continuous in time. This is why it probably makes sense to have
> library support for an "exact final time".
I am fine if you say that the interface is at the continuum level, but then
the user should not be getting back
output that depends on the discretization.
Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111023/5648900f/attachment.html>
