[petsc-dev] TSSolve() shouldn't return a time
Jed Brown
jedbrown at mcs.anl.gov
Sun Oct 23 16:01:14 CDT 2011
On Sun, Oct 23, 2011 at 15:58, Matthew Knepley <knepley at gmail.com> wrote:
> I am fine if you say that the interface is at the continuum level, but then
> the user should not be getting back
> output that depends on the discretization.
So you are saying that -ts_exact_final_time should be the default? I don't
think it should be the only interface because sometimes the user really
doesn't care because exact times have no significance to them, and it's less
expensive to not hit an exact time (possibly one less vector too).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111023/3d737eea/attachment.html>
