[petsc-dev] size of PetscInt without grepping include
Barry Smith
bsmith at mcs.anl.gov
Tue Oct 18 18:08:24 CDT 2011
On Oct 18, 2011, at 6:03 PM, Ethan Coon wrote:
> On Tue, 2011-10-18 at 17:54 -0500, Matthew Knepley wrote:
>> You would need the whole BuildSystem in order to interpret it (and
>> maybe the PETSc parts as well).
> Right, which defeats the purpose of having a python module that gets
> installed with PETSc to read/write binary files from python.
> I guess the way to get this info is to parse both petscconf.h and
> petscvariables to pull out datatypes used in the binary files. The
> matlab scripts doing binary IO require you to know this ahead of time,
> but that seems a little silly when we should be able to get this info
> from the installation. I just assumed that all of this would be defined
> somewhere in petscvariables.
At configure time we could generate a MATLAB and Python "include file" that defined those things in a natural way. Then the various MATLAB and Python scripts would include that one configure generated file to get the definitions directly without the need for ugly parsing of petscvariables/petscconf.h each time the scripts are run.
Barry
> Ethan
>> I
>> don't think this is that bad. Python does not have the Java
>> serialization model.
>> Matt
>> Ethan
>>> Matt
>>> Ethan
>>> On Tue, 2011-10-18 at 16:24 -0500, Barry Smith
>> wrote:
>>>> PETSC_USE_64BIT_INDICES
>>> Ethan Coon
>>> Post-Doctoral Researcher
>>> Applied Mathematics - T-5
>>> Los Alamos National Laboratory
>>> 505-665-8289
>>> http://www.ldeo.columbia.edu/~ecoon/
>>> What most experimenters take for granted before they begin
>> their
>>> experiments is infinitely more interesting than any results
>> to which
>>> their experiments lead.
>>> -- Norbert Wiener
>> Ethan Coon
>> 505-665-8289
>> experiments is infinitely more interesting than any results to which
>> -- Norbert Wiener
> Ethan Coon
> 505-665-8289
