[petsc-dev] size of PetscInt without grepping include
Tue Oct 18 18:11:13 CDT 2011
On Tue, Oct 18, 2011 at 6:03 PM, Ethan Coon <ecoon at lanl.gov> wrote:
> On Tue, 2011-10-18 at 17:54 -0500, Matthew Knepley wrote:
> > You would need the whole BuildSystem in order to interpret it (and
> > maybe the PETSc parts as well).
> Right, which defeats the purpose of having a python module that gets
> installed with PETSc to read/write binary files from python.
I don't think it defeats the purpose at all. We should be installing
BuildSystem.
I hate the idea of generated a whole bunch of custom, unsupported metadata
that will bitrot away in a year.
   Matt
> I guess the way to get this info is to parse both petscconf.h and
> petscvariables to pull out datatypes used in the binary files.  The
> matlab scripts doing binary IO require you to know this ahead of time,
> but that seems a little silly when we should be able to get this info
> from the installation.  I just assumed that all of this would be defined
> somewhere in petscvariables.
> Ethan
> > I
> > don't think this is that bad. Python does not have the Java
> > serialization model.
> >     Matt
> >         Ethan
> >         >      Matt
> >         >         Ethan
> >         >         On Tue, 2011-10-18 at 16:24 -0500, Barry Smith
> >         wrote:
> >         >         > PETSC_USE_64BIT_INDICES
> >         >         Ethan Coon
> >         >         Post-Doctoral Researcher
> >         >         Applied Mathematics - T-5
> >         >         Los Alamos National Laboratory
> >         >         505-665-8289
> >         >         http://www.ldeo.columbia.edu/~ecoon/
> >         > What most experimenters take for granted before they begin
> >         their
> >         > experiments is infinitely more interesting than any results
> >         to which
> >         > their experiments lead.
> >         > -- Norbert Wiener
> >         Ethan Coon
> >         505-665-8289
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > -- Norbert Wiener
> Ethan Coon
> 505-665-8289
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111018/6e1eade1/attachment.html>
