[petsc-dev] I have a problem in using Petsc
    Jed Brown
    jedbrown at mcs.anl.gov
    Wed Oct 12 07:47:58 CDT 2011
2011/10/11 Guoyin Wang <guoyinwang.pku at gmail.com>
> I type in this in terminal:wgy at ubuntu:~/petsc-dev$ ./configure
> --download-mpich=yes --download-hdf5=yes. But the result is :TESTING: check
> from
> config.libraries(config/BuildSystem/config/libraries.py:133)*******************************************************************************
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> Downloaded hdf5 could not be used. Please check install in
> /home/wgy/petsc-dev/arch-linux2-c-debug
> Could you help me to deal with this problem?
Send configure.log to petsc-maint at mcs.anl.gov
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111012/27425b90/attachment.html>
