[petsc-dev] Handling DM local functions with TS
Jed Brown
jedbrown at mcs.anl.gov
Tue Oct 11 22:32:52 CDT 2011
I'd like to have some automatic way to use coloring with TS as long as I
provide a residual evaluation function. In the current approach, if I don't
do anything special, it fails because there are no TS functions on the DM.
Barry, how would you like to go about fixing this?
./ex26 -da_grid_x 20 -da_grid_y 20 -lidvelocity 100 -grashof 1e3
-ts_max_steps 100 -ts_rtol 1e-3 -ts_atol 1e-3 -ts_type rosw -ts_rosw_type
ra3pw -ts_monitor -ts_monitor_solution_vtk 'foo-%03D.vts'
20x20 grid, lid velocity = 100, prandtl # = 1, grashof # = 1000
0 TS dt 0.025 time 0
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Object is in wrong state!
[0]PETSC ERROR: Must call MatFDColoringSetFunction()!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Development HG revision:
f25e2c7d799b418675085efb3f389141e0dd9d6e HG Date: Sat Oct 01 17:17:01 2011
-0500
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./ex26 on a ompi named batura by jed Tue Oct 11 22:25:15
[0]PETSC ERROR: Libraries linked from /home/jed/petsc/ompi/lib
[0]PETSC ERROR: Configure run at Sun Oct 2 10:41:14 2011
[0]PETSC ERROR: Configure options --download-blacs --download-hypre
--download-ml --download-mumps --download-parmetis --download-scalapack
--download-spai --download-sundials --download-superlu
--download-superlu_dist --download-umfpack --with-parmetis-dir=/usr
--with-rosw --with-shared-libraries --with-single-library=0 --with-sowing
PETSC_ARCH=ompi --download-parms
[0]PETSC ERROR:
[0]PETSC ERROR: MatFDColoringApply() line 515 in
/home/jed/petsc/src/mat/matfd/fdmatrix.c
[0]PETSC ERROR: DMComputeJacobianDefault() line 813 in
/home/jed/petsc/src/dm/interface/dm.c
[0]PETSC ERROR: DMComputeJacobian() line 1290 in
[0]PETSC ERROR: SNESDMComputeJacobian() line 23 in
/home/jed/petsc/src/snes/interface/snes.c
[0]PETSC ERROR: SNESComputeJacobian() line 1410 in
[0]PETSC ERROR: SNESSolve_KSPONLY() line 32 in
/home/jed/petsc/src/snes/impls/ksponly/ksponly.c
[0]PETSC ERROR: SNESSolve() line 2793 in
[0]PETSC ERROR: TSStep_RosW() line 669 in
/home/jed/petsc/src/ts/impls/rosw/rosw.c
[0]PETSC ERROR: TSStep() line 1813 in /home/jed/petsc/src/ts/interface/ts.c
[0]PETSC ERROR: TSSolve() line 1929 in /home/jed/petsc/src/ts/interface/ts.c
[0]PETSC ERROR: main() line 164 in src/ts/examples/tutorials/ex26.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111011/c09f3f4c/attachment.html>
