[petsc-dev] hdf5.py needing libz hardwired?
Dmitry Karpeev karpeev at mcs.anl.gov
Wed Oct 12 05:52:33 CDT 2011
libz can also be downloaded and built from sources more or less trivially.
On Wed, Oct 12, 2011 at 4:55 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   In BuildSystem/packages/hdf5.py it depends on libz but just checks that
> at the same time as checking the hdf5 libraries. Shouldn't hdf5.py depend on
> libz.py and then libz.py does a clean check for libz and tells the user the
> proper fix it if does not find it. For example listing the Linux package
> commands for getting it if not installed? Current code requires PETSc
> developer to tell the user what to do each time.
>   Can someone fix this?
>   Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111012/40ed64b6/attachment.html>
