[petsc-dev] [petsc-maint #89809] 3D DMDAs in petsc-3.2
    Jed Brown
    jedbrown at mcs.anl.gov
    Sun Oct  9 23:01:42 CDT 2011
On Sun, Oct 9, 2011 at 22:54, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Jed,
>       It appears your  some of your many
> if (s_t >= x*y*z) {s_t = bases[n26] + (i-1)*x_t;} /* 2d case */
> things are breaking the communication with a stencil width of 2
da3.c:980
M-x xhg-ann<RET>
Looks like that line comes from
changeset:   18790:4310a5aad280
user:        Ethan Coon <ecoon at lanl.gov>
date:        Wed Apr 20 00:57:49 2011 +0200
summary:     cruft to handle the special case of solving a 2D problem in a
3D algorithm with stencil size > 1.  This only works in the 3D case,
z-dimension
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/4310a5a
> the second layer of ghost points uses the first layer instead of getting
> the second layer.
> Since I don't understand your /* 2d case */ business I leave it to you to
> fix
I don't understand it either and haven't tried. Maybe Ethan can take a look.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111009/c6739e2b/attachment.html>
