[petsc-dev] [petsc-maint #89809] 3D DMDAs in petsc-3.2
    Barry Smith
    bsmith at mcs.anl.gov
    Sun Oct  9 22:54:42 CDT 2011
   Jed,
       It appears your  some of your many
if (s_t >= x*y*z) {s_t = bases[n26] + (i-1)*x_t;} /* 2d case */
things are breaking the communication with a stencil width of 2
In src/dm/examples/tests/ex38.c  in petsc-3.2
barry-smiths-macbook-pro:tests barrysmith$ petscmpiexec -n 2  ./ex38
Vector Object: 1 MPI processes
  type: seq
0
1
2
3
4
5
6
7
8
9
10
11
112
113
114
115
116
117
112
113
114
115
116
117
the second layer of ghost points uses the first layer instead of getting the second layer.
Since I don't understand your /* 2d case */ business I leave it to you to fix
So either I still have a bug in my test code (always possible) or you've introduced your first bug into PETSc (seems unlikely),
   Barry
On Oct 9, 2011, at 8:09 PM, Jed Brown wrote:
> Ex48 uses periodic in y and z and it works.
> On Oct 9, 2011 8:08 PM, "Barry Smith" <bsmith at mcs.anl.gov> wrote:
>  Ok 3.1-p8 also fails with the same problems. Likely periodic boundary conditions have never worked in 3d? Yikes this looks bad
>  Barry
> On Oct 9, 2011, at 3:28 PM, Barry Smith wrote:
> >   I have created a new test example in petsc-3.2 for 3D global to local with periodic boundary conditions and it fails rather completely so whomever introduced all the IXs, IXe stuff into DMSetUp_DA_3d() likely introduced some bugs, or the bugs have always been there and no one has tested it properly.
> > For example (with periodicity indicated only in the x direction) one gets:
> > barry-smiths-macbook-pro:tests barrysmith$ petscmpiexec -n 2 ./ex38 -da_view -stencil_width 1 | more
> > Processor [0] M 2 N 3 P 4 m 1 n 1 p 2 w 1 s 1
> > X range of indices: 0 2, Y range of indices: 0 3, Z range of indices: 0 2
> > Processor [1] M 2 N 3 P 4 m 1 n 1 p 2 w 1 s 1
> > X range of indices: 0 2, Y range of indices: 0 3, Z range of indices: 2 4
> >  type: seq
> > 1
> > 0
> > 1
> > 0
> > 3
> > 2
> > 3
> > 2
> > 5
> > 4
> > 5
> > 4
> > 7
> > 6
> > 7
> > 6
> > 9
> > 8
> > 9
> > 8
> > 11
> > 10
> > 11
> > 10
> > -1
> > 112
> > 113
> > -1
> > -1
> > 114
> > 115
> > -1
> > -1
> > 116
> > 117
> > -1
> > so it is not properly handling the periodicity on the "ghost plane" brought over from the rank 1 process to the rank 0.
> > Note this happens also with a stencil width of 1, so it is not just a question of not handling the stencil width correctly.
> >  Barry
> > On Oct 9, 2011, at 1:32 PM, Richard Katz wrote:
> >> Here's how I set up the problem:
> >>   ierr = DMDACreate3d(user->comm,DMDA_BOUNDARY_PERIODIC,DMDA_BOUNDARY_PERIODIC,DMDA_BOUNDARY_NONE,
> >>                      DMDA_STENCIL_BOX,p->Ni,p->Nj,p->Nk,1,1,PETSC_DECIDE,
> >>                      (PetscInt)(sizeof(SolVel3D)/sizeof(PetscReal)),2,
> >>                      PETSC_NULL,PETSC_NULL,PETSC_NULL,&user->dav);CHKERRQ(ierr);
> >> ierr = DMCreateGlobalVector(user->dav,&user->v);CHKERRQ(ierr);
> >> ierr = DMCreateGlobalVector(user->daa,&user->an);CHKERRQ(ierr);
> >> ierr = VecDuplicate(user->v,&user->vo);CHKERRQ(ierr);
> >> ierr = VecDuplicate(user->v,&user->vm);CHKERRQ(ierr);
> >> ierr = VecDuplicate(user->v,&user->rv);CHKERRQ(ierr);
> >> ierr = VecDuplicate(user->an,&user->ano);CHKERRQ(ierr);
> >> ierr = SNESCreate(user->comm,&user->snes);CHKERRQ(ierr);
> >> if (D2(p)) { ierr = SNESSetFunction(user->snes,user->rv,FormResidual_v2d,user);CHKERRQ(ierr); }
> >> else       { ierr = SNESSetFunction(user->snes,user->rv,FormResidual_v3d,user);CHKERRQ(ierr); }
> >> ierr = DMGetColoring(user->dav,IS_COLORING_GLOBAL,MATAIJ,&iscoloring);
> >> ierr = DMGetMatrix(user->dav,MATAIJ,&user->Jv);CHKERRQ(ierr);
> >> ierr = MatFDColoringCreate(user->Jv,iscoloring,&user->mfdcv);
> >> ierr = MatFDColoringSetFromOptions(user->mfdcv);CHKERRQ(ierr);
> >> if (D2(p)) { ierr = MatFDColoringSetFunction(user->mfdcv,(PetscErrorCode(*)(void))FormResidual_v2d,user); }
> >> else       { ierr = MatFDColoringSetFunction(user->mfdcv,(PetscErrorCode(*)(void))FormResidual_v3d,user); }
> >> ierr = SNESSetJacobian(user->snes,user->Jv,user->Jv,SNESDefaultComputeJacobianColor,user->mfdcv);
> >> ierr = ISColoringDestroy(&iscoloring);
> >> ierr = SNESSetOptionsPrefix(user->snes,"PV_");CHKERRQ(ierr);
> >> ierr = SNESSetFromOptions(user->snes);CHKERRQ(ierr);
> >> D2(p) is a macro that returns 1 if the problem is 2D, and 0 if 3D.
> >> Rich
> >> On 9 Oct 2011, at 19:30, Barry Smith wrote:
> >>> box stencil or star stencil?
> >>> On Oct 9, 2011, at 1:26 PM, Richard Katz wrote:
> >>>> On 9 Oct 2011, at 19:24, Barry Smith wrote:
> >>>>> To clarify: With this build valgrind generates no messages at all?
> >>>> That's correct.
> >>>> [magmox:test]$ $PETSC_DIR/bin/petscmpiexec -valgrind -n 2 ../porbandsim -nd 3 -alpha 2 -theta 45 -output_file test2
> >>>> --94613-- run: /usr/bin/dsymutil "../porbandsim"
> >>>> --94612-- run: /usr/bin/dsymutil "../porbandsim"
> >>>> --------------porbandsim: Sun Oct  9 17:24:24 2011---------------
> >>>> Processes: 2, DOFs/Process: 2800
> >>>> #PETSc Option Table entries:
> >>>> -PV_snes_converged_reason
> >>>> -PV_snes_monitor
> >>>> -alpha 2
> >>>> -ksp_gmres_restart 150
> >>>> -nd 3
> >>>> -output_file test2
> >>>> -snes_converged_reason
> >>>> -snes_monitor
> >>>> -theta 45
> >>>> #End of PETSc Option Table entries
> >>>> PetscBag Object:  ParameterBag params for porosity band simulation
> >>>> takei = TRUE; Use Takei & Holztman (2009) viscosity (T/F)
> >>>> hperm = FALSE; Use harmonic mean for computing permeability (T/F)
> >>>> lambda = 27; Porosity-weakening exponent in shear viscosity, dim'less
> >>>> R = 0.57735; Ratio compaction length to domain height, dim'less
> >>>> sigma_sat = 1; Saturation stress-difference for anisotropy, dim'less
> >>>> n = 3; Exponent in porosity--permeability relationship, dim'less
> >>>> phi0 = 0.1; Initial porosity, dim'less
> >>>> phi1 = 0.01; Amplitude of porosity perturbation, dim'less
> >>>> theta = 45; Fixed anisotropy angle, degrees (-1234567 indicates dynamic)
> >>>> alpha = 2; Fixed anisotropy magnitude, 0<=alpha<=2 (-1234567 indicates dynamic)
> >>>> viscratio = 1.66667; Ratio of bulk to shear viscosity at phi=phi0, dim'less
> >>>> nsig = 1; Exponent in stress--strain rate relationship, dim'less
> >>>> init_harmonic = FALSE; Use harmonic perturbation as IC (T/F)
> >>>> input_file = null; Name base for input porosity file
> >>>> test = FALSE; Just load parameters and then exit
> >>>> output_file = test2; Name base for output files
> >>>> output_all = FALSE; Make output after each time-step (T/F)
> >>>> output_err = TRUE; Make output after failed time-step (T/F)
> >>>> output_aux = TRUE; Output auxilliary fields (T/F)
> >>>> converged = TRUE; Indicates whether a time-step converged (NO SET)
> >>>> nb = 2; Number of buffer rows at top and bottom of domain
> >>>> ns = 1000000; Maximum number of time-steps
> >>>> nits = 1; Number of Picard iterations
> >>>> nplot = 0; Output counter
> >>>> advect = 1; Advection scheme: 0=FV, 1=Fromm, 2=TVD
> >>>> time = 0; Time at current step, dim'less
> >>>> cfl = 0.5; Courant-Friedrichs-Lewy number, dim'less
> >>>> tmax = 20; Maximimum simulated time, dim'less
> >>>> tout = 0.05; Output interval, dim'less
> >>>> nd = 3; Number of spatial dimensions, 2 or 3
> >>>> ni = 20; Grid points in x-direction (shear-direction, periodic)
> >>>> nj = 5; Grid points in y-direction (cross-direction, periodic)
> >>>> nk = 14; Grid points in z-direction, incl buffer points
> >>>> -------------------------END PARAM REPORT------------------------
> >>>> Continuation in lambda for initial condition
> >>>> 0 SNES Function norm 2.512586736188e+01
> >>>> 1 SNES Function norm 2.149396609776e-03
> >>>> 2 SNES Function norm 1.863405745330e-08
> >>>> Nonlinear solve converged due to CONVERGED_FNORM_ABS
> >>>> Solved with lambda = 1.0 in 205.35 seconds
> >>>> 0 SNES Function norm 1.874271649438e+00
> >>>> 1 SNES Function norm 8.642606950729e-06
> >>>> 2 SNES Function norm 7.636114324949e-11
> >>>> Solved with lambda = 2.0 in 206.47 seconds
> >>>> 0 SNES Function norm 3.748572573117e+00
> >>>> 1 SNES Function norm 1.823985563954e-05
> >>>> 2 SNES Function norm 1.446658479082e-10
> >>>> Solved with lambda = 4.0 in 207.02 seconds
> >>>> 0 SNES Function norm 7.498313656718e+00
> >>>> 1 SNES Function norm 3.949293531885e-05
> >>>> 2 SNES Function norm 3.092503935042e-10
> >>>> Solved with lambda = 8.0 in 207.44 seconds
> >>>> 0 SNES Function norm 1.500973207738e+01
> >>>> 1 SNES Function norm 8.256012403101e-05
> >>>> 2 SNES Function norm 6.728525270322e-10
> >>>> Solved with lambda = 16.0 in 207.38 seconds
> >>>> 0 SNES Function norm 2.066862203903e+01
> >>>> 1 SNES Function norm 6.201694512543e-05
> >>>> 2 SNES Function norm 5.537777484572e-10
> >>>> Solved with lambda = 27.0 in 207.32 seconds
> >>>> Generating output file: "test2_0000"
> >>>> 0 SNES Function norm 1.914413986104e+01
> >>>> 1 SNES Function norm 7.835942994856e-05
> >>>> 2 SNES Function norm 2.520454050827e-10
> >>>> 0 SNES Function norm 2.038885321297e+01
> >>>> 1 SNES Function norm 1.727646593582e-04
> >>>> 2 SNES Function norm 1.325429214752e-09
> >>>> Stepped to time t = 0.050 in 213.4 seconds
> >>>> Generating output file: "test2_0001"
> >>>> 0 SNES Function norm 1.592319862889e+01
> >>>> 1 SNES Function norm 5.602653646480e-05
> >>>> 2 SNES Function norm 2.453571869974e-10
> >>>> 0 SNES Function norm 1.321599310609e+01
> >>>> 1 SNES Function norm 1.261023473773e-04
> >>>> 2 SNES Function norm 1.163959209038e-09
> >>>> Stepped to time t = 0.100 in 212.6 seconds
> >>>> Generating output file: "test2_0002"
> >>>> 0 SNES Function norm 1.422948512067e+01
> >>>> 1 SNES Function norm 4.242156538283e-05
> >>>> 2 SNES Function norm 1.625303993154e-10
> >>>> 0 SNES Function norm 9.675556760630e+00
> >>>> 1 SNES Function norm 1.362209365650e-04
> >>>> 2 SNES Function norm 1.223382062021e-09
> >>>> Stepped to time t = 0.150 in 212.9 seconds
> >>>> Generating output file: "test2_0003"
> >>>> 0 SNES Function norm 1.307890574732e+01
> >>>> 1 SNES Function norm 3.214708350215e-05
> >>>> 2 SNES Function norm 1.093103013350e-10
> >>>> 0 SNES Function norm 7.636762082099e+00
> >>>> 1 SNES Function norm 1.308928801753e-04
> >>>> 2 SNES Function norm 1.143217709967e-09
> >>>> Stepped to time t = 0.200 in 212.8 seconds
> >>>> Generating output file: "test2_0004"
> >>>> 0 SNES Function norm 1.216229064046e+01
> >>>> 1 SNES Function norm 2.441284335468e-05
> >>>> 2 SNES Function norm 7.517551623210e-11
> >>>> 0 SNES Function norm 6.371107649815e+00
> >>>> 1 SNES Function norm 1.185031269819e-04
> >>>> 2 SNES Function norm 1.095566218658e-09
> >>>> Stepped to time t = 0.250 in 213.0 seconds
> >>>> Generating output file: "test2_0005"
> >>>> 0 SNES Function norm 1.136564194223e+01
> >>>> 1 SNES Function norm 1.865453423897e-05
> >>>> 2 SNES Function norm 5.239501925142e-11
> >>>> 0 SNES Function norm 5.520895480607e+00
> >>>> 1 SNES Function norm 1.025932275448e-04
> >>>> 2 SNES Function norm 1.071648118984e-09
> >>>> Stepped to time t = 0.300 in 213.0 seconds
> >>>> Generating output file: "test2_0006"
> >>>> 0 SNES Function norm 1.064481900239e+01
> >>>> 1 SNES Function norm 1.438574893573e-05
> >>>> 2 SNES Function norm 3.643963189108e-11
> >>>> 0 SNES Function norm 4.905069034291e+00
> >>>> 1 SNES Function norm 8.961489700096e-05
> >>>> 2 SNES Function norm 1.008198626576e-09
> >>>> Stepped to time t = 0.350 in 212.7 seconds
> >>>> Generating output file: "test2_0007"
> >>>> 0 SNES Function norm 9.981300326125e+00
> >>>> 1 SNES Function norm 1.120717450009e-05
> >>>> 2 SNES Function norm 2.503394538611e-11
> >>>> 0 SNES Function norm 4.428377952757e+00
> >>>> ^CCtrl-C caught... cleaning up processes
> >>>>> Barry
> >>>>> On Oct 9, 2011, at 12:19 PM, Richard Katz wrote:
> >>>>>> Hi Barry,
> >>>>>> I have now run the code with
> >>>>>> configure_options = [
> >>>>>> '--download-mpich=1',
> >>>>>> '--with-cxx=0',
> >>>>>> '--with-fortran=0',
> >>>>>> 'PETSC_ARCH=debug_mpich',
> >>>>>> and
> >>>>>> The memory error goes away.
> >>>>>> The error in the calculated solution does not go away.
> >>>>>> Thanks,
> >>>>>> Rich
> >>>>>> On 9 Oct 2011, at 17:01, Barry Smith wrote:
> >>>>>>> Rich,
> >>>>>>> Could you do an identical run (to the valgrind run you made below) but using another PETSC_ARCH that uses --download-mpich
> >>>>>>> I am suspecting openmpi because it is a bad read of something INSIDE OpenMPI that was just outside the range of memory allocated BY OpenMPI, it is hard to see how PETSc could induce this particular memory problem.
> >>>>>>> Of course, it is also possible there are two bugs, one in OpenMPI and another in PETSc related to the DMDA.
> >>>>>>> Barry
> >>>>>>> On Oct 9, 2011, at 10:46 AM, Richard Katz wrote:
> >>>>>>>> Hi all,
> >>>>>>>> I'm beginning to wonder if there is a bug in the filling of ghost-points for 3-dimensional DMDAs under petsc-3.2. I am working on a finite-volume code that uses a DMDACreate3d() to create several DMDAs, all with a stencil width of two.
> >>>>>>>> * The 2-dimensional mode for the same code runs without problems in parallel.
> >>>>>>>> * The initial SNES solve converges well, with no seg-faults, but when there are processor bounds in the k-direction, the solution is clearly incorrect at/near the boundaries.
> >>>>>>>> * When I run the same code in serial, or in parallel but with no processor boundaries in the k-direction, it works without problems.
> >>>>>>>> * When I run the code with processor boundaries in the k-direction, but zeroing-out the bits of the stencil that are at stencil-radius of 2, the processor-boundary errors don't appear.
> >>>>>>>> * Extending the stencil width to 3 has no effect on the problem.
> >>>>>>>> * There does seem to be a memory-corruption problem, but I'm not sure where it comes from, because it appears very high in the stack.  The following is valgrind output for a run with 2 processors.  The processor boundary is in the k-direction.  This memory error ONLY appears on the first SNES solve, but not on any of the following ones.  Also, the memory error seems to be associated with OpenMPI; it doesn't occur when running with MPICH2
> >>>>>>>> [magmox:test]$ $PETSC_DIR/bin/petscmpiexec -valgrind -n 2 ../porbandsim -malloc off -nd 3 -alpha 2 -theta 45 -output_file test2
> >>>>>>>> ==4576== Invalid read of size 8
> >>>>>>>> ==4576==    at 0x7FFFFFE00BAC: ???
> >>>>>>>> ==4576==    by 0x101A34213: ompi_convertor_pack (in /usr/lib/libmpi.0.dylib)
> >>>>>>>> ==4576==    by 0x10858909E: mca_pml_ob1_send_request_start_copy (in /usr/lib/openmpi/mca_pml_ob1.so)
> >>>>>>>> ==4576==    by 0x1085840D2: mca_pml_ob1_isend (in /usr/lib/openmpi/mca_pml_ob1.so)
> >>>>>>>> ==4576==    by 0x1085D11C3: ompi_coll_tuned_allreduce_intra_recursivedoubling (in /usr/lib/openmpi/mca_coll_tuned.so)
> >>>>>>>> ==4576==    by 0x101A4419B: MPI_Allreduce (in /usr/lib/libmpi.0.dylib)
> >>>>>>>> ==4576==    by 0x1001D3F3E: VecMDot_MPI (pvec2.c:20)
> >>>>>>>> ==4576==    by 0x100204669: VecMDot (rvector.c:1144)
> >>>>>>>> ==4576==    by 0x10097E28B: KSPGMRESClassicalGramSchmidtOrthogonalization (borthog2.c:66)
> >>>>>>>> ==4576==    by 0x100975B33: GMREScycle (gmres.c:159)
> >>>>>>>> ==4576==    by 0x10097656E: KSPSolve_GMRES (gmres.c:231)
> >>>>>>>> ==4576==    by 0x1009A8606: KSPSolve (itfunc.c:423)
> >>>>>>>> ==4576==    by 0x100A0271A: SNES_KSPSolve (snes.c:3396)
> >>>>>>>> ==4576==    by 0x100A17F79: SNESSolve_LS (ls.c:190)
> >>>>>>>> ==4576==    by 0x1009FB635: SNESSolve (snes.c:2676)
> >>>>>>>> ==4576==    by 0x100008104: InitSolveElliptic (initialize.c:216)
> >>>>>>>> ==4576==    by 0x10000538A: FormInitialCondition (initialize.c:31)
> >>>>>>>> ==4576==    by 0x100001410: main (porbandsim.c:28)
> >>>>>>>> ==4576==  Address 0x10289f778 is 0 bytes after a block of size 136 alloc'd
> >>>>>>>> ==4576==    at 0x1010B05BF: malloc (vg_replace_malloc.c:266)
> >>>>>>>> ==4576==    by 0x1085D0F98: ompi_coll_tuned_allreduce_intra_recursivedoubling (in /usr/lib/openmpi/mca_coll_tuned.so)
> >>>>>>>> ==4576==
> >>>>>>>> ==4577== Invalid read of size 8
> >>>>>>>> ==4577==    at 0x7FFFFFE00BAC: ???
> >>>>>>>> ==4577==    by 0x101A34213: ompi_convertor_pack (in /usr/lib/libmpi.0.dylib)
> >>>>>>>> ==4577==    by 0x10858909E: mca_pml_ob1_send_request_start_copy (in /usr/lib/openmpi/mca_pml_ob1.so)
> >>>>>>>> ==4577==    by 0x1085840D2: mca_pml_ob1_isend (in /usr/lib/openmpi/mca_pml_ob1.so)
> >>>>>>>> ==4577==    by 0x1085D11C3: ompi_coll_tuned_allreduce_intra_recursivedoubling (in /usr/lib/openmpi/mca_coll_tuned.so)
> >>>>>>>> ==4577==    by 0x101A4419B: MPI_Allreduce (in /usr/lib/libmpi.0.dylib)
> >>>>>>>> ==4577==    by 0x1001D3F3E: VecMDot_MPI (pvec2.c:20)
> >>>>>>>> ==4577==    by 0x100204669: VecMDot (rvector.c:1144)
> >>>>>>>> ==4577==    by 0x10097E28B: KSPGMRESClassicalGramSchmidtOrthogonalization (borthog2.c:66)
> >>>>>>>> ==4577==    by 0x100975B33: GMREScycle (gmres.c:159)
> >>>>>>>> ==4577==    by 0x10097656E: KSPSolve_GMRES (gmres.c:231)
> >>>>>>>> ==4577==    by 0x1009A8606: KSPSolve (itfunc.c:423)
> >>>>>>>> ==4577==    by 0x100A0271A: SNES_KSPSolve (snes.c:3396)
> >>>>>>>> ==4577==    by 0x100A17F79: SNESSolve_LS (ls.c:190)
> >>>>>>>> ==4577==    by 0x1009FB635: SNESSolve (snes.c:2676)
> >>>>>>>> ==4577==    by 0x100008104: InitSolveElliptic (initialize.c:216)
> >>>>>>>> ==4577==    by 0x10000538A: FormInitialCondition (initialize.c:31)
> >>>>>>>> ==4577==    by 0x100001410: main (porbandsim.c:28)
> >>>>>>>> ==4577==  Address 0x10289f778 is 0 bytes after a block of size 136 alloc'd
> >>>>>>>> ==4577==    at 0x1010B05BF: malloc (vg_replace_malloc.c:266)
> >>>>>>>> ==4577==    by 0x1085D0F98: ompi_coll_tuned_allreduce_intra_recursivedoubling (in /usr/lib/openmpi/mca_coll_tuned.so)
> >>>>>>>> ==4577==
> >>>>>>>> Any suggestions about how to debug this?  How well-tested are the parallel, 3D DMDA routines?  Should I do some testing on a PETSc example code?
> >>>>>>>> I am running petsc-3.2 with
> >>>>>>>> changeset:   20338:fbd00cf1070e
> >>>>>>>> tag:         tip
> >>>>>>>> parent:      20337:589176156279
> >>>>>>>> parent:      20336:7abcced43e69
> >>>>>>>> user:        Barry Smith <bsmith at mcs.anl.gov>
> >>>>>>>> date:        Tue Oct 04 16:45:00 2011 -0500
> >>>>>>>> summary:     commit after merge
> >>>>>>>> and
> >>>>>>>> '--download-fftw=true',
> >>>>>>>> '--with-cxx=0',
> >>>>>>>> '--with-debugging=1',
> >>>>>>>> '--with-fortran=0',
> >>>>>>>> '--with-mpi-dir=/usr',
> >>>>>>>> 'PETSC_ARCH=debug',
> >>>>>>>> or
> >>>>>>>> '--download-blacs',
> >>>>>>>> '--download-mpich=yes',
> >>>>>>>> '--download-mumps=yes',
> >>>>>>>> '--download-parmetis',
> >>>>>>>> '--download-scalapack',
> >>>>>>>> '--with-cxx=0',
> >>>>>>>> '--with-debugging=0',
> >>>>>>>> 'PETSC_ARCH=optimize_mumps',
> >>>>>>>> Thanks,
> >>>>>>>> Rich
> >>>>>> ________________________________
> >>>>>> Richard Foa Katz
> >>>>>> Dept Earth Sciences, Univ Oxford
> >>>>>> http://foalab.earth.ox.ac.uk
> >>>> Richard Foa Katz
> >> Richard Foa Katz
