[petsc-dev] [petsc-maint #88993] Petsc with Cuda 4.0 and Multiple GPUs
Dave Nystrom
Dave.Nystrom at tachyonlogic.com
Sun Oct 2 22:50:54 CDT 2011
Hi Barry,
Barry Smith writes:
> Dave,
> I cannot explain why it does not use the MatMult_SeqAIJCusp() - it does for me.
Do you get good performance running a problem like ex2?
> Have you updated to the latest cusp/thrust? From the mecurial repositories?
I did try the latest version of cusp from mercurial initially but the build
failed. So I am currently using the latest cusp tarball. I did not try the
latest version of thrust but instead was just using what came with the
released version of Cuda 4.0. I could try the mercurial versions of both.
> There is a difference, in your new 4.0 build you added
> --download-txpetscgpu=yes BTW: that doesn't work for me with the latest
> cusp and thrust from the mecurial repositories can you try reconfiguring
> and making without that?
Yes, I can try that. Maybe that is why my original build with cusp from
mercurial failed.
Thanks for your help,
Dave
> Barry
> On Oct 2, 2011, at 9:08 PM, Dave Nystrom wrote:
>> Barry Smith writes:
>>> On Oct 2, 2011, at 6:39 PM, Dave Nystrom wrote:
>>>> Thanks for the update. I don't believe I have gotten a run with good
>>>> performance yet, either from C or Fortran. I wish there was an easy way for
>>>> me to force use of only one of my gpus. I don't want to have to pull one of
>>>> the gpus in order to see if that is complicating things with Cuda 4.0. I'll
>>>> be eager to hear if you make any progress on figuring things out.
>>>> Do you understand yet why the petsc ex2.c example is able to parse the
>>>> "-cuda_show_devices" argument but ex2f.F does not?
>>> Matt put the code in the wrong place in PETSc, that is all, no big
>>> existentialist reason. I will fix that.
>> Thanks. I'll look forward to testing out the new version.
>> Dave
>>> Barry
>>>> Thanks,
>>>> Dave
>>>> Barry Smith writes:
>>>>> It is not doing the MatMult operation on the GPU and hence needs to move
>>>>> the vectors back and forth for each operation (since MatMult is done on
>>>>> the CPU with the vector while vector operations are done on the GPU) hence
>>>>> the terrible performance.
>>>>> Not sure why yet. It is copying the Mat down for me from C.
>>>>> Barry
>>>>> On Oct 2, 2011, at 4:18 PM, Dave Nystrom wrote:
>>>>>> In case it might be useful, I have attached two log files of runs with the
>>>>>> ex2f petsc example from src/ksp/ksp/examples/tutorials. One was run back in
>>>>>> April with petsc-dev linked to Cuda 3.2. It shows excellent runtime
>>>>>> performance. The other was run today with petsc-dev checked out of the
>>>>>> mercurial repo yesterday morning and linked to Cuda 4.0. In addition to the
>>>>>> differences in run time performance, I also do not see an entry for
>>>>>> MatCUSPCopyTo in the profiling section. I'm not sure what the significance
>>>>>> of that is. I do observe that the run time for PCApply is about the same for
>>>>>> the two cases. I think I would expect that to be the case even if the
>>>>>> problem were partitioned across two gpus. However, it does make me wonder if
>>>>>> the absence of MatCUSPCopyTo in the profiling section of the Cuda 4.0 log
>>>>>> file is an indication that the matrix was not actually copied to the gpu.
>>>>>> I'm not sure yet how to check for that. Hope this might be useful.
>>>>>> Thanks,
>>>>>> Dave
>>>>>> <ex2f_3200_3200_cuda_yes_cuda_3.2.log><ex2f_3200_3200_cuda_yes_cuda_4.0.log>
>>>>>> Dave Nystrom writes:
>>>>>>> Matthew Knepley writes:
>>>>>>>> On Sat, Oct 1, 2011 at 11:26 PM, Dave Nystrom <Dave.Nystrom at tachyonlogic.com> wrote:
>>>>>>>>> Barry Smith writes:
>>>>>>>>>> On Oct 1, 2011, at 9:22 PM, Dave Nystrom wrote:
>>>>>>>>>>> Hi Barry,
>>>>>>>>>>> I've sent a couple more emails on this topic. What I am trying to do at the
>>>>>>>>>>> moment is to figure out how to have a problem run on only one gpu if it will
>>>>>>>>>>> fit in the memory of that gpu. Back in April when I had built petsc-dev with
>>>>>>>>>>> Cuda 3.2, petsc would only use one gpu if you had multiple gpus on your
>>>>>>>>>>> machine. In order to use multiple gpus for a problem, one had to use
>>>>>>>>>>> multiple threads with a separate thread assigned to control each gpu. But
>>>>>>>>>>> Cuda 4.0 has, I believe, made that transparent and under the hood. So now
>>>>>>>>>>> when I run a small example problem such as
>>>>>>>>>>> src/ksp/ksp/examples/tutorials/ex2f.F with an 800x800 problem, it gets
>>>>>>>>>>> partitioned to run on both of the gpus in my machine. The result is a very
>>>>>>>>>>> large performance hit because of communication back and forth from one gpu to
>>>>>>>>>>> the other via the cpu.
>>>>>>>>>> How do you know there is lots of communication from the GPU to the CPU? In
>>>>>>>>>> the -log_summary? Nope because PETSc does not manage anything like that
>>>>>>>>>> (that is one CPU process using both GPUs).
>>>>>>>>> What I believe is that it is being managed by Cuda 4.0, not by petsc.
>>>>>>>>>>> So this problem with a 3200x3200 grid runs 5x slower
>>>>>>>>>>> now than it did with Cuda 3.2. I believe if one is programming down at the
>>>>>>>>>>> cuda level, it is possible to have a smaller problem run on only one gpu so
>>>>>>>>>>> that there is communication only between the cpu and gpu and only at the
>>>>>>>>>>> start and end of the calculation.
>>>>>>>>>>> To me, it seems like what is needed is a petsc option to specify the number
>>>>>>>>>>> of gpus to run on that can somehow get passed down to the cuda level through
>>>>>>>>>>> cusp and thrust. I fear that the short term solution is going to have to be
>>>>>>>>>>> for me to pull one of the gpus out of my desktop system but it would be nice
>>>>>>>>>>> if there was a way to tell petsc and friends to just use one gpu when I want
>>>>>>>>>>> it to.
>>>>>>>>>>> If necessary, I can send a couple of log files to demonstrate what I am
>>>>>>>>>>> trying to describe regarding the performance hit.
>>>>>>>>>> I am not convinced that the poor performance you are getting now has
>>>>>>>>>> anything to do with using both GPUs. Please run a PETSc program with the
>>>>>>>>>> command -cuda_show_devices
>>>>>>>>> I ran the following command:
>>>>>>>>> ex2f -m 8 -n 8 -ksp_type cg -pc_type jacobi -log_summary -cuda_show_devices
>>>>>>>>> -mat_type aijcusp -vec_type cusp -options_left
>>>>>>>>> The result was a report that there was one option left, that being
>>>>>>>>> -cuda_show_devices. I am using a copy of petsc-dev that I cloned and built
>>>>>>>>> this morning.
>>>>>>>> What do you have at src/sys/object/pinit.c:825? You should see the code
>>>>>>>> that processes this option. You should be able to break there in the
>>>>>>>> debugger and see what happens. This sounds again like you are not
>>>>>>>> processing options correctly.
>>>>>>> Hi Matt,
>>>>>>> I'll take a look at that in a bit and see if I can figure out what is going
>>>>>>> on. I do see the code that you mention that processes the arguments that
>>>>>>> Barry mentioned. In terms of processing options correctly, at least in this
>>>>>>> case I am actually running one of the petsc examples rather than my own
>>>>>>> code. And it seems to correctly process the other command line arguments.
>>>>>>> Anyway, I'll write more after I have had a chance to investigate more.
>>>>>>> Thanks,
>>>>>>> Dave
>>>>>>>> Matt
>>>>>>>>>> What are the choices? You can then pick one of them and run with
>>>>>>>>> -cuda_set_device integer
>>>>>>>>> The -cuda_set_device option does not appear to be recognized either, even
>>>>>>>>> if I choose an integer like 0.
>>>>>>>>>> Does this change things?
>>>>>>>>> I suspect it would change things if I could get it to work.
>>>>>>>>> Thanks,
>>>>>>>>> Dave
>>>>>>>>>> Barry
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Dave
>>>>>>>>>>> Barry Smith writes:
>>>>>>>>>>>> Dave,
>>>>>>>>>>>> We have no mechanism in the PETSc code for a PETSc single CPU process to
>>>>>>>>>>>> use two GPUs at the same time. However you could have two MPI processes
>>>>>>>>>>>> each using their own GPU.
>>>>>>>>>>>> The one tricky part is you need to make sure each MPI process uses a
>>>>>>>>>>>> different GPU. We currently do not have a mechanism to do this assignment
>>>>>>>>>>>> automatically. I think it can be done with cudaSetDevice(). But I don't
>>>>>>>>>>>> know the details, sending this to petsc-dev at mcs.anl.gov where more people
>>>>>>>>>>>> may know.
>>>>>>>>>>>> PETSc-folks,
>>>>>>>>>>>> We need a way to have this setup automatically.
>>>>>>>>>>>> Barry
>>>>>>>>>>>> On Oct 1, 2011, at 5:43 PM, Dave Nystrom wrote:
>>>>>>>>>>>>> I'm running petsc on a machine with Cuda 4.0 and 2 gpus. This is a desktop
>>>>>>>>>>>>> machine with a single processor. I know that Cuda 4.0 has support for
>>>>>>>>>>>>> running on multiple gpus but don't know if petsc uses that. But suppose I
>>>>>>>>>>>>> have a problem that will fit in the memory for a single gpu. Will petsc run
>>>>>>>>>>>>> the problem on a single gpu or does it split it between the 2 gpus and incur
>>>>>>>>>>>>> the communication overhead of copying data between the two gpus?
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Dave
>>>>>>>> What most experimenters take for granted before they begin their experiments
>>>>>>>> is infinitely more interesting than any results to which their experiments
>>>>>>>> lead.
>>>>>>>> -- Norbert Wiener
