[petsc-dev] [petsc-maint #88993] Petsc with Cuda 4.0 and Multiple GPUs
Barry Smith
bsmith at mcs.anl.gov
Sun Oct 2 21:43:28 CDT 2011
Dave,
I cannot explain why it does not use the MatMult_SeqAIJCusp() it does for me.
Have you updated to the latest cusp/thrust? From the mecurial repositories
There is a difference, in your new 4.0 build you added --download-txpetscgpu=yes BTW: that doesn't work for me with the latest cusp and thrust from the mecurial repositories can you try reconfiguring and making without that?
Barry
On Oct 2, 2011, at 9:08 PM, Dave Nystrom wrote:
> Barry Smith writes:
>> On Oct 2, 2011, at 6:39 PM, Dave Nystrom wrote:
>>> Thanks for the update. I don't believe I have gotten a run with good
>>> performance yet, either from C or Fortran. I wish there was an easy way for
>>> me to force use of only one of my gpus. I don't want to have to pull one of
>>> the gpus in order to see if that is complicating things with Cuda 4.0. I'll
>>> be eager to hear if you make any progress on figuring things out.
>>> Do you understand yet why the petsc ex2.c example is able to parse the
>>> "-cuda_show_devices" argument but ex2f.F does not?
>> Matt put the code in the wrong place in PETSc, that is all, no big
>> existentialist reason. I will fix that.
> Thanks. I'll look forward to testing out the new version.
> Dave
>> Barry
>>> Thanks,
>>> Dave
>>> Barry Smith writes:
>>>> It is not doing the MatMult operation on the GPU and hence needs to move
>>>> the vectors back and forth for each operation (since MatMult is done on
>>>> the CPU with the vector while vector operations are done on the GPU) hence
>>>> the terrible performance.
>>>> Not sure why yet. It is copying the Mat down for me from C.
>>>> Barry
>>>> On Oct 2, 2011, at 4:18 PM, Dave Nystrom wrote:
>>>>> In case it might be useful, I have attached two log files of runs with the
>>>>> ex2f petsc example from src/ksp/ksp/examples/tutorials. One was run back in
>>>>> April with petsc-dev linked to Cuda 3.2. It shows excellent runtime
>>>>> performance. The other was run today with petsc-dev checked out of the
>>>>> mercurial repo yesterday morning and linked to Cuda 4.0. In addition to the
>>>>> differences in run time performance, I also do not see an entry for
>>>>> MatCUSPCopyTo in the profiling section. I'm not sure what the significance
>>>>> of that is. I do observe that the run time for PCApply is about the same for
>>>>> the two cases. I think I would expect that to be the case even if the
>>>>> problem were partitioned across two gpus. However, it does make me wonder if
>>>>> the absence of MatCUSPCopyTo in the profiling section of the Cuda 4.0 log
>>>>> file is an indication that the matrix was not actually copied to the gpu.
>>>>> I'm not sure yet how to check for that. Hope this might be useful.
>>>>> Thanks,
>>>>> Dave
>>>>> <ex2f_3200_3200_cuda_yes_cuda_3.2.log><ex2f_3200_3200_cuda_yes_cuda_4.0.log>
>>>>> Dave Nystrom writes:
>>>>>> Matthew Knepley writes:
>>>>>>> On Sat, Oct 1, 2011 at 11:26 PM, Dave Nystrom <Dave.Nystrom at tachyonlogic.com> wrote:
>>>>>>>> Barry Smith writes:
>>>>>>>>> On Oct 1, 2011, at 9:22 PM, Dave Nystrom wrote:
>>>>>>>>>> Hi Barry,
>>>>>>>>>> I've sent a couple more emails on this topic. What I am trying to do at the
>>>>>>>>>> moment is to figure out how to have a problem run on only one gpu if it will
>>>>>>>>>> fit in the memory of that gpu. Back in April when I had built petsc-dev with
>>>>>>>>>> Cuda 3.2, petsc would only use one gpu if you had multiple gpus on your
>>>>>>>>>> machine. In order to use multiple gpus for a problem, one had to use
>>>>>>>>>> multiple threads with a separate thread assigned to control each gpu. But
>>>>>>>>>> Cuda 4.0 has, I believe, made that transparent and under the hood. So now
>>>>>>>>>> when I run a small example problem such as
>>>>>>>>>> src/ksp/ksp/examples/tutorials/ex2f.F with an 800x800 problem, it gets
>>>>>>>>>> partitioned to run on both of the gpus in my machine. The result is a very
>>>>>>>>>> large performance hit because of communication back and forth from one gpu to
>>>>>>>>>> the other via the cpu.
>>>>>>>>> How do you know there is lots of communication from the GPU to the CPU? In
>>>>>>>>> the -log_summary? Nope because PETSc does not manage anything like that
>>>>>>>>> (that is one CPU process using both GPUs).
>>>>>>>> What I believe is that it is being managed by Cuda 4.0, not by petsc.
>>>>>>>>>> So this problem with a 3200x3200 grid runs 5x slower
>>>>>>>>>> now than it did with Cuda 3.2. I believe if one is programming down at the
>>>>>>>>>> cuda level, it is possible to have a smaller problem run on only one gpu so
>>>>>>>>>> that there is communication only between the cpu and gpu and only at the
>>>>>>>>>> start and end of the calculation.
>>>>>>>>>> To me, it seems like what is needed is a petsc option to specify the number
>>>>>>>>>> of gpus to run on that can somehow get passed down to the cuda level through
>>>>>>>>>> cusp and thrust. I fear that the short term solution is going to have to be
>>>>>>>>>> for me to pull one of the gpus out of my desktop system but it would be nice
>>>>>>>>>> if there was a way to tell petsc and friends to just use one gpu when I want
>>>>>>>>>> it to.
>>>>>>>>>> If necessary, I can send a couple of log files to demonstrate what I am
>>>>>>>>>> trying to describe regarding the performance hit.
>>>>>>>>> I am not convinced that the poor performance you are getting now has
>>>>>>>>> anything to do with using both GPUs. Please run a PETSc program with the
>>>>>>>>> command -cuda_show_devices
>>>>>>>> I ran the following command:
>>>>>>>> ex2f -m 8 -n 8 -ksp_type cg -pc_type jacobi -log_summary -cuda_show_devices
>>>>>>>> -mat_type aijcusp -vec_type cusp -options_left
>>>>>>>> The result was a report that there was one option left, that being
>>>>>>>> -cuda_show_devices. I am using a copy of petsc-dev that I cloned and built
>>>>>>>> this morning.
>>>>>>> What do you have at src/sys/object/pinit.c:825? You should see the code
>>>>>>> that processes this option. You should be able to break there in the
>>>>>>> debugger and see what happens. This sounds again like you are not
>>>>>>> processing options correctly.
>>>>>> Hi Matt,
>>>>>> I'll take a look at that in a bit and see if I can figure out what is going
>>>>>> on. I do see the code that you mention that processes the arguments that
>>>>>> Barry mentioned. In terms of processing options correctly, at least in this
>>>>>> case I am actually running one of the petsc examples rather than my own
>>>>>> code. And it seems to correctly process the other command line arguments.
>>>>>> Anyway, I'll write more after I have had a chance to investigate more.
>>>>>> Thanks,
>>>>>> Dave
>>>>>>> Matt
>>>>>>>>> What are the choices? You can then pick one of them and run with
>>>>>>>> -cuda_set_device integer
>>>>>>>> The -cuda_set_device option does not appear to be recognized either, even
>>>>>>>> if I choose an integer like 0.
>>>>>>>>> Does this change things?
>>>>>>>> I suspect it would change things if I could get it to work.
>>>>>>>> Thanks,
>>>>>>>> Dave
>>>>>>>>> Barry
>>>>>>>>>> Thanks,
>>>>>>>>>> Dave
>>>>>>>>>> Barry Smith writes:
>>>>>>>>>>> Dave,
>>>>>>>>>>> We have no mechanism in the PETSc code for a PETSc single CPU process to
>>>>>>>>>>> use two GPUs at the same time. However you could have two MPI processes
>>>>>>>>>>> each using their own GPU.
>>>>>>>>>>> The one tricky part is you need to make sure each MPI process uses a
>>>>>>>>>>> different GPU. We currently do not have a mechanism to do this assignment
>>>>>>>>>>> automatically. I think it can be done with cudaSetDevice(). But I don't
>>>>>>>>>>> know the details, sending this to petsc-dev at mcs.anl.gov where more people
>>>>>>>>>>> may know.
>>>>>>>>>>> PETSc-folks,
>>>>>>>>>>> We need a way to have this setup automatically.
>>>>>>>>>>> Barry
>>>>>>>>>>> On Oct 1, 2011, at 5:43 PM, Dave Nystrom wrote:
>>>>>>>>>>>> I'm running petsc on a machine with Cuda 4.0 and 2 gpus. This is a desktop
>>>>>>>>>>>> machine with a single processor. I know that Cuda 4.0 has support for
>>>>>>>>>>>> running on multiple gpus but don't know if petsc uses that. But suppose I
>>>>>>>>>>>> have a problem that will fit in the memory for a single gpu. Will petsc run
>>>>>>>>>>>> the problem on a single gpu or does it split it between the 2 gpus and incur
>>>>>>>>>>>> the communication overhead of copying data between the two gpus?
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Dave
>>>>>>> What most experimenters take for granted before they begin their experiments
>>>>>>> is infinitely more interesting than any results to which their experiments
>>>>>>> lead.
>>>>>>> -- Norbert Wiener
