[petsc-dev] [petsc-maint #88993] Petsc with Cuda 4.0 and Multiple GPUs
Matthew Knepley
petsc-maint at mcs.anl.gov
Mon Oct 3 08:24:01 CDT 2011
On Sun, Oct 2, 2011 at 10:50 PM, Dave Nystrom <Dave.Nystrom at tachyonlogic.com
> wrote:
> Hi Barry,
> Barry Smith writes:
> > Dave,
> > I cannot explain why it does not use the MatMult_SeqAIJCusp() - it does
> for me.
> Do you get good performance running a problem like ex2?
Okay, now the problem is clear. This does not have to do with having 2 GPUs,
rather you
were not running MatMult on any GPU.
This problem has to do with the 'da_mat_type aijcusp' option being passed
in. Somehow this
is not being acted on. So, we need
- The full input
- The full output of the test using -log_summary
Matt
> > Have you updated to the latest cusp/thrust? From the mecurial
> repositories?
> I did try the latest version of cusp from mercurial initially but the build
> failed. So I am currently using the latest cusp tarball. I did not try
> the
> latest version of thrust but instead was just using what came with the
> released version of Cuda 4.0. I could try the mercurial versions of both.
> > There is a difference, in your new 4.0 build you added
> > --download-txpetscgpu=yes BTW: that doesn't work for me with the latest
> > cusp and thrust from the mecurial repositories can you try reconfiguring
> > and making without that?
> Yes, I can try that. Maybe that is why my original build with cusp from
> mercurial failed.
> Thanks for your help,
> Dave
> > Barry
> > On Oct 2, 2011, at 9:08 PM, Dave Nystrom wrote:
> >> Barry Smith writes:
> >>> On Oct 2, 2011, at 6:39 PM, Dave Nystrom wrote:
> >>>> Thanks for the update. I don't believe I have gotten a run with good
> >>>> performance yet, either from C or Fortran. I wish there was an easy
> way for
> >>>> me to force use of only one of my gpus. I don't want to have to pull
> one of
> >>>> the gpus in order to see if that is complicating things with Cuda
> 4.0. I'll
> >>>> be eager to hear if you make any progress on figuring things out.
> >>>> Do you understand yet why the petsc ex2.c example is able to parse
> the
> >>>> "-cuda_show_devices" argument but ex2f.F does not?
> >>> Matt put the code in the wrong place in PETSc, that is all, no big
> >>> existentialist reason. I will fix that.
> >> Thanks. I'll look forward to testing out the new version.
> >> Dave
> >>> Barry
> >>>> Thanks,
> >>>> Dave
> >>>> Barry Smith writes:
> >>>>> It is not doing the MatMult operation on the GPU and hence needs to
> move
> >>>>> the vectors back and forth for each operation (since MatMult is done
> on
> >>>>> the CPU with the vector while vector operations are done on the GPU)
> hence
> >>>>> the terrible performance.
> >>>>> Not sure why yet. It is copying the Mat down for me from C.
> >>>>> Barry
> >>>>> On Oct 2, 2011, at 4:18 PM, Dave Nystrom wrote:
> >>>>>> In case it might be useful, I have attached two log files of runs
> with the
> >>>>>> ex2f petsc example from src/ksp/ksp/examples/tutorials. One was
> run back in
> >>>>>> April with petsc-dev linked to Cuda 3.2. It shows excellent
> runtime
> >>>>>> performance. The other was run today with petsc-dev checked out of
> the
> >>>>>> mercurial repo yesterday morning and linked to Cuda 4.0. In
> addition to the
> >>>>>> differences in run time performance, I also do not see an entry for
> >>>>>> MatCUSPCopyTo in the profiling section. I'm not sure what the
> significance
> >>>>>> of that is. I do observe that the run time for PCApply is about
> the same for
> >>>>>> the two cases. I think I would expect that to be the case even if
> the
> >>>>>> problem were partitioned across two gpus. However, it does make me
> wonder if
> >>>>>> the absence of MatCUSPCopyTo in the profiling section of the Cuda
> 4.0 log
> >>>>>> file is an indication that the matrix was not actually copied to
> the gpu.
> >>>>>> I'm not sure yet how to check for that. Hope this might be useful.
> >>>>>> Thanks,
> >>>>>> Dave
> <ex2f_3200_3200_cuda_yes_cuda_3.2.log><ex2f_3200_3200_cuda_yes_cuda_4.0.log>
> >>>>>> Dave Nystrom writes:
> >>>>>>> Matthew Knepley writes:
> >>>>>>>> On Sat, Oct 1, 2011 at 11:26 PM, Dave Nystrom <
> Dave.Nystrom at tachyonlogic.com> wrote:
> >>>>>>>>> Barry Smith writes:
> >>>>>>>>>> On Oct 1, 2011, at 9:22 PM, Dave Nystrom wrote:
> >>>>>>>>>>> Hi Barry,
> >>>>>>>>>>> I've sent a couple more emails on this topic. What I am
> trying to do at the
> >>>>>>>>>>> moment is to figure out how to have a problem run on only one
> gpu if it will
> >>>>>>>>>>> fit in the memory of that gpu. Back in April when I had built
> petsc-dev with
> >>>>>>>>>>> Cuda 3.2, petsc would only use one gpu if you had multiple
> gpus on your
> >>>>>>>>>>> machine. In order to use multiple gpus for a problem, one had
> to use
> >>>>>>>>>>> multiple threads with a separate thread assigned to control
> each gpu. But
> >>>>>>>>>>> Cuda 4.0 has, I believe, made that transparent and under the
> hood. So now
> >>>>>>>>>>> when I run a small example problem such as
> >>>>>>>>>>> src/ksp/ksp/examples/tutorials/ex2f.F with an 800x800 problem,
> it gets
> >>>>>>>>>>> partitioned to run on both of the gpus in my machine. The
> result is a very
> >>>>>>>>>>> large performance hit because of communication back and forth
> from one gpu to
> >>>>>>>>>>> the other via the cpu.
> >>>>>>>>>> How do you know there is lots of communication from the GPU to
> the CPU? In
> >>>>>>>>>> the -log_summary? Nope because PETSc does not manage anything
> like that
> >>>>>>>>>> (that is one CPU process using both GPUs).
> >>>>>>>>> What I believe is that it is being managed by Cuda 4.0, not by
> petsc.
> >>>>>>>>>>> So this problem with a 3200x3200 grid runs 5x slower
> >>>>>>>>>>> now than it did with Cuda 3.2. I believe if one is
> programming down at the
> >>>>>>>>>>> cuda level, it is possible to have a smaller problem run on
> only one gpu so
> >>>>>>>>>>> that there is communication only between the cpu and gpu and
> only at the
> >>>>>>>>>>> start and end of the calculation.
> >>>>>>>>>>> To me, it seems like what is needed is a petsc option to
> specify the number
> >>>>>>>>>>> of gpus to run on that can somehow get passed down to the cuda
> level through
> >>>>>>>>>>> cusp and thrust. I fear that the short term solution is going
> to have to be
> >>>>>>>>>>> for me to pull one of the gpus out of my desktop system but it
> would be nice
> >>>>>>>>>>> if there was a way to tell petsc and friends to just use one
> gpu when I want
> >>>>>>>>>>> it to.
> >>>>>>>>>>> If necessary, I can send a couple of log files to demonstrate
> what I am
> >>>>>>>>>>> trying to describe regarding the performance hit.
> >>>>>>>>>> I am not convinced that the poor performance you are getting
> now has
> >>>>>>>>>> anything to do with using both GPUs. Please run a PETSc program
> with the
> >>>>>>>>>> command -cuda_show_devices
> >>>>>>>>> I ran the following command:
> >>>>>>>>> ex2f -m 8 -n 8 -ksp_type cg -pc_type jacobi -log_summary
> -cuda_show_devices
> >>>>>>>>> -mat_type aijcusp -vec_type cusp -options_left
> >>>>>>>>> The result was a report that there was one option left, that
> being
> >>>>>>>>> -cuda_show_devices. I am using a copy of petsc-dev that I
> cloned and built
> >>>>>>>>> this morning.
> >>>>>>>> What do you have at src/sys/object/pinit.c:825? You should see
> the code
> >>>>>>>> that processes this option. You should be able to break there in
> the
> >>>>>>>> debugger and see what happens. This sounds again like you are not
> >>>>>>>> processing options correctly.
> >>>>>>> Hi Matt,
> >>>>>>> I'll take a look at that in a bit and see if I can figure out what
> is going
> >>>>>>> on. I do see the code that you mention that processes the
> arguments that
> >>>>>>> Barry mentioned. In terms of processing options correctly, at
> least in this
> >>>>>>> case I am actually running one of the petsc examples rather than
> my own
> >>>>>>> code. And it seems to correctly process the other command line
> arguments.
> >>>>>>> Anyway, I'll write more after I have had a chance to investigate
> more.
> >>>>>>> Thanks,
> >>>>>>> Dave
> >>>>>>>> Matt
> >>>>>>>>>> What are the choices? You can then pick one of them and run
> with
> >>>>>>>>> -cuda_set_device integer
> >>>>>>>>> The -cuda_set_device option does not appear to be recognized
> either, even
> >>>>>>>>> if I choose an integer like 0.
> >>>>>>>>>> Does this change things?
> >>>>>>>>> I suspect it would change things if I could get it to work.
> >>>>>>>>> Thanks,
> >>>>>>>>> Dave
> >>>>>>>>>> Barry
> >>>>>>>>>>> Thanks,
> >>>>>>>>>>> Dave
> >>>>>>>>>>> Barry Smith writes:
> >>>>>>>>>>>> Dave,
> >>>>>>>>>>>> We have no mechanism in the PETSc code for a PETSc single CPU
> process to
> >>>>>>>>>>>> use two GPUs at the same time. However you could have two MPI
> processes
> >>>>>>>>>>>> each using their own GPU.
> >>>>>>>>>>>> The one tricky part is you need to make sure each MPI process
> uses a
> >>>>>>>>>>>> different GPU. We currently do not have a mechanism to do
> this assignment
> >>>>>>>>>>>> automatically. I think it can be done with cudaSetDevice().
> But I don't
> >>>>>>>>>>>> know the details, sending this to petsc-dev at mcs.anl.govwhere more people
> >>>>>>>>>>>> may know.
> >>>>>>>>>>>> PETSc-folks,
> >>>>>>>>>>>> We need a way to have this setup automatically.
> >>>>>>>>>>>> Barry
> >>>>>>>>>>>> On Oct 1, 2011, at 5:43 PM, Dave Nystrom wrote:
> >>>>>>>>>>>>> I'm running petsc on a machine with Cuda 4.0 and 2 gpus.
> This is a desktop
> >>>>>>>>>>>>> machine with a single processor. I know that Cuda 4.0 has
> support for
> >>>>>>>>>>>>> running on multiple gpus but don't know if petsc uses that.
> But suppose I
> >>>>>>>>>>>>> have a problem that will fit in the memory for a single gpu.
> Will petsc run
> >>>>>>>>>>>>> the problem on a single gpu or does it split it between the
> 2 gpus and incur
> >>>>>>>>>>>>> the communication overhead of copying data between the two
> gpus?
> >>>>>>>>>>>>> Thanks,
> >>>>>>>>>>>>> Dave
> >>>>>>>> What most experimenters take for granted before they begin their
> experiments
> >>>>>>>> is infinitely more interesting than any results to which their
> experiments
> >>>>>>>> lead.
> >>>>>>>> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111003/4737981f/attachment-0001.html>
