[petsc-dev] metis config error on XT4
    Aron Ahmadia
    aron.ahmadia at kaust.edu.sa
    Wed Nov 30 16:32:59 CST 2011
Mark,
Sorry, no help here, except that cmake is pretty easy to install from
source, so that might be my recommendation if you don't want to wait for
help from their systems team.
A
On Thu, Dec 1, 2011 at 1:30 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
> Thanks Tim, I do use gcc. And this is on Franklin at NERSC.
> Cmake is just kicking my ass, now I get (appended).
> I do have an old version of cmake here:
> madams/petsc-dev> which cmake
> /usr/common/usg/cmake/2.8.3/bin/cmake
> any ideas?
> Mark
>                                           Configuring METIS; this may take
> several minutes
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> Error running configure on METIS: Could not execute "cd
> /global/u2/m/madams/petsc-dev/externalpackages/metis-5.0.2 && make
> distclean && make config
> prefix=/global/homes/m/madams/petsc-dev/arch-xt5-opt cc="cc"
> doubleprecision=1":
> rm -rf build/Linux-x86_64
> mkdir -p build/Linux-x86_64
> cd build/Linux-x86_64 && cmake
> -DCMAKE_VERBOSE_MAKEFILE=1 -DGKLIB_PATH=
> -DCMAKE_INSTALL_PREFIX=/global/homes/m/madams/petsc-dev/arch-xt5-opt
> -DCMAKE_C_COMPILER=cc -DMETIS_USE_DOUBLEPRECISION=1
> -- The C compiler identification is GNU
> -- The CXX compiler identification is GNU
> -- Check for working C compiler: /opt/cray/xt-asyncpe/5.01/bin/cc
> -- Check for working C compiler: /opt/cray/xt-asyncpe/5.01/bin/cc -- works
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - done
> -- Check for working CXX compiler: /opt/gcc/4.5.3/bin/c++
> -- Check for working CXX compiler: /opt/gcc/4.5.3/bin/c++ -- works
> -- Detecting CXX compiler ABI info
> -- Detecting CXX compiler ABI info - done
> -- Configuring incomplete, errors occurred!
> CMake Error at CMakeLists.txt:21 (include):
>   include could not find load file:
>     /GKlibSystem.cmake
> make: *** [config] Error 1
> On Nov 30, 2011, at 4:00 PM, Tim Gallagher wrote:
> Without knowing how your system is configured, this may not help. But on
> the Cray systems we use (they have the modules package installed), if we
> are using a compiler other than GNU (Intel, PGI, etc) but we want to use
> cmake, we still have to load the gcc module (not the programming
> environment, just the module).
> On our machines, it means we may load the PrgEnv-Intel module (so cc
> points to icc, ftn points to ifort, etc) but we also have to load
> gcc/<version> to get cmake to work.
> Tim
> *From: *"Aron Ahmadia" <aron.ahmadia at kaust.edu.sa>
> *To: *"For users of the development version of PETSc" <
> petsc-dev at mcs.anl.gov>
> *Sent: *Wednesday, November 30, 2011 3:49:25 PM
> *Subject: *Re: [petsc-dev] metis config error on XT4
> looks like a broken cmake...
> What happens when you just run: cmake by itself?
> A
> On Wed, Nov 30, 2011 at 11:47 PM, Mark F. Adams <mark.adams at columbia.edu>
> wrote:
>> I'm getting this error on Franklin at NERSC:
>> details):
>> doubleprecision=1":
>> cmake: /opt/gcc/4.5.3/snos/lib64/libstdc++.so.6: version `GLIBCXX_3.4.15'
>> not found (required by cmake)
>> any ideas?
>> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111201/380e9790/attachment.html>
