[petsc-dev] Generality of VecScatter
    Dmitry Karpeev
    karpeev at mcs.anl.gov
    Tue Nov 29 08:52:56 CST 2011
>From what I understand Barry doesn't want the threads to spin.
Also, synchronizing through an unguarded memory location seems to create a
race conditions.
Isn't cmpxchg instruction-set specific?
Dmitry.
On Tue, Nov 29, 2011 at 8:50 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> You don't need any of this unless your threads need to actually sleep
> instead of spin. I think we can afford to have them spin, so we don't need
> any locking. You let the threads continue by doing an ordinary write to a
> memory location. (You can do more sophisticated things with cmpxchg, which
> you likely need at synchronization points.)
>  On Nov 29, 2011 8:41 AM, "Dmitry Karpeev" <karpeev at mcs.anl.gov> wrote:
>> Barry,
>> You might want to take a look at this:
>> http://stackoverflow.com/questions/2994216/linux-pthread-suspend
>> The solution suggested there (Answer 1) is to use sigwait().  Answer 3,
>> although not the actual solution,
>> explains why the  pthread_suspend/pthread_continue-based solution is
>> racy. I think this may be a general issue
>> with the problem, which requires the use of mutexes.
>> What example do you use to test this?  I'd like to take a look.
>> Thanks.
>> Dmitry.
>> On Thu, Nov 24, 2011 at 4:10 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> On Thu, Nov 24, 2011 at 16:01, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>   Yes, but they can only get access to that shared variable one at a
>>>> time: first get's it, then second get's it, then third gets, .... Ok for a
>>>> couple of cores but not for dozens.
>>>>   Take a look at src/sys/objects/pthread.c for the various ways we have
>>>> coded for "waking" the threads. Maybe I am missing something but this is
>>>> the best Kerry and I could figure out.
>>> What exactly should I be looking at? Can't you have all the threads spin
>>> on a normal shared variable (not a mutex) that is only written by the
>>> thread that needs to spark them? Or use a fetch-and-add atomic if you want
>>> to keep track of how many are running or limit the number? The latter could
>>> use a tree to get logarithmic cost, but if they are stored next to each
>>> other, you would still have O(P) cache invalidations.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111129/003df1fa/attachment.html>
