[petsc-dev] Generality of VecScatter
Jed Brown
jedbrown at mcs.anl.gov
Tue Nov 29 09:08:02 CST 2011
On Tue, Nov 29, 2011 at 08:52, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
> >From what I understand Barry doesn't want the threads to spin.
Lots of MPI calls spin because it's MUCH lower latency. Unless we have more
threads than cores, what is the problem?
> Also, synchronizing through an unguarded memory location seems to create a
> race conditions.
Not if writes are atomic. There is always a way to do atomic writes
(usually machine-word) because otherwise the operating system could not
implement synchronization primitives.
Isn't cmpxchg instruction-set specific?
All instruction sets have some analogue of cmpxchg because it's the
building block for all other primitives.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111129/5c31198d/attachment.html>
